Author Topic: Autodesk Eagle PCB cutouts  (Read 1647 times)
Offline csheldonTopic starter
« on: December 27, 2018, 09:44:54 am »
Hi all,
Some help for a noob here please :)
I want to be able to do two things:
1) I want a slot-like trace cutout of preffered length and shape on the pcb
2) I want to cut out piece of pcb on the edge...basically something like defining board shape..but it's not shape rather it's simple cut out.
How can I do these two things..?
Offline Chriss
Re: Autodesk Eagle PCB cutouts
« Reply #1 on: December 27, 2018, 10:03:08 am »
Hi!
I assume you will do the cutting with a cnc?
Sent from my GT-I8260 using Tapatalk
Offline westfw
« Reply #2 on: December 29, 2018, 08:52:39 am »
This is normally more dependent on the the board fabricator than on the PCB editor.I would draw lines/shapes on the "routing" layer, using a width equal to my tool width.  But most board fabs seems to want an outline of the actual slot, usually in the dimension layer, sometimes with a drill hole in a starting position.   (The one time I tried to get slots (for a USB connector) done in a board, it didn't come out :-( )   Check your board vendor's web page for info on "internal milling."
usually you can do that just by modifying the "dimension" layer - there is no reason that it has to be a rectangle.
The following users thanked this post: spec
