Author Topic: "Automagic" window roller control  (Read 594 times)
Offline PinheadBETopic starter
  • Pinball Freak
« on: January 06, 2020, 12:28:15 pm »
Hi there,
I'm looking for a commercial solution to replace the manual up/down switch of my rollers with an automated one which should be able to open/close the rollers based on, for example, the official dusk/dawn times for my location (manually override able)
I've seen some fairly inexpensive switches (less than 50 EUR), which are programmable through an Android app, but I don't know if I need something else in the infrastructure for them to work (a server of some kind or whatever...)
--> Is such a switch, connected to the WiFi enough to work independently once programmed through the App, or does it need something else ?
--> Do you have, based on your experience, some examples of fairly reliable models to guide me ?
Any advice welcome !
Thanks a lot !
Please keep our planet clean
