Author Topic: Automatic 12V power source switching to battery backup  (Read 320 times)
Offline newtekuserTopic starter
« on: December 25, 2024, 03:13:54 am »
I am working on a simple 12V power source switching circuit using a P-channel mosfet and LTC4412 IC. The idea is to automatically switch to 12V battery backup if the primary power is out. I'm prioritizing the primary by adding a schottky diode to create a small voltage drop on the backup. Can someone please chime in if I messed something up in the wiring? Schematic attached.
Thanks in advance!
Offline Terry Bites
Re: Automatic 12V power source switching to battery backup
« Reply #1 on: December 25, 2024, 02:59:47 pm »
Just before I have my lovely lunch.....
Your schematic shows the MOSFET is shorted out?
It should look like this:
The following users thanked this post: newtekuser
« Reply #2 on: December 25, 2024, 05:58:59 pm »
It should look like this: (Attachment Link)
Oops, I very much misunderstood the operation of the IC. Corrected.
So, the VIN of the IC is connected to the backup source and not the primary source, or is that depending on whether I want to monitor when the backup goes offline instead of the main power?
Also, for "prioritization" of main power over battery (to prevent battery from being used when main is active), is the use of a schottky diode to create a voltage drop the right approach?
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #3 on: December 26, 2024, 11:37:01 am »
Wrong again. D1 polarity is wrong, and cathode of D8 should be connected to D of MOSFET
« Reply #4 on: December 26, 2024, 12:57:45 pm »
Thank you! It's 5am but 3rd time's a charm ::)
« Last Edit: December 26, 2024, 01:27:59 pm by newtekuser »
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #5 on: December 26, 2024, 01:25:00 pm »
Now it looks correct
