Author Topic: I need help with Half bridge driver IC IR2184  (Read 363 times)
Offline CarabusTopic starter
  • Country: lt
« on: April 12, 2022, 04:01:08 pm »
What do Vb and Vs do? how it affects the circuit?
Here's how I imagine the driver:
https://ibb.co/gJPpk9p
https://ibb.co/G0W017D
the top MOSFET would need 24v, and the bottom one 12v, right?
also, how do I configure (if it's possible) for one output to use 24v instead of 12v, and lastly does this ic have some kind of prevention of shoot-throughs?
  • Country: lt
Re: I need help with Half bridge driver IC IR2184
« Reply #1 on: April 12, 2022, 04:12:19 pm »
I might have figured it out in multisim, is it for setting the bootstrap voltage of the one output which drives mosfet which needs to be bootstrapped?
Offline Sauli
« Reply #2 on: April 12, 2022, 04:39:47 pm »
The way you 'imagine' to use it won't work. Unless you have a third power supply higher than 24V and the 12V power supply can sink the load current.
Actually the case where the lower MOSFET conducts works. But for the upper MOSFET to conduct you need to supply VB with a higher voltage than VS is. The capacitor in the typical connection of the data sheet won't last long to keep the upper MOSFET conducting. If you had a voltage higher than 24V you could connect it directly to VB to keep the MOSFET conducting.
Typically this chip is used to change the current direction in a motor winding, and two chips are needed for that.
The dead time of IR2184 is 500ns, that is the time from shutting down one MOSFET to opening the other.
  • Country: lt
« Reply #3 on: April 12, 2022, 04:45:43 pm »
Thanks for the reply, I'll use a capacitor voltage divider with big value capacitors, or if I get my hands on a dual power supply.
