Author Topic: Automotive oscilloscope test leads question  (Read 579 times)
Offline Chris WilsonTopic starter
  • Race car engineer, dog lover, hoarder.
« on: November 17, 2019, 01:34:59 pm »
Can I use 50 Ohm co-ax to make my own (much cheaper) 100MHz scope probe extension leads similar to these please/
https://www.picoauto.com/products//test-leads/premium-test-lead-3m-bnc-to-4mm-black-permanent-ground
Most of my work is looking at real time signal from things like ABS (wheel speed sensors), both analogue and digital where I need a long lead to reach from within a vehicle to underneath, for a laptop connected USB scope. Thanks.
Best regards,
                 Chris Wilson.
Offline soldar
Re: Automotive oscilloscope test leads question
« Reply #1 on: November 17, 2019, 03:04:59 pm »
I don't know what kind of bandwidth you really need but I have managed fine with coax of any kind or even twisted pair. Heck, I am sending base band video over twisted pair right now with fine results. I think it's when you are up into hundreds of MHz and longer distances that you need to start being more careful. A length of coax or CAT5 should work well, I think.
The following users thanked this post: Chris Wilson
« Reply #2 on: November 17, 2019, 03:58:02 pm »
OK, thanks, as my twisted pair stuff (CAT cable) is solid core and as coax seems easier to terminate in BNC I'll try some RG-58, much appreciated.
Best regards,
                 Chris Wilson.
