Hello everyone this is my first post, I am but a humble novice in need of your electronics knowledge and expertise... Which will be greatly appreciated of course!
I have bought a device that consists of a bucket with a water inlet at the bottom, inside there is small water pump and a float switch which are wired to a small junction box that is fixed to the outside of the bucket.
As water fills the bucket the float switch activates the pump which then pumps water out of the bucket to where I need it.
So I decided to take a look inside the junction box to see exactly how it is wired.
My thinking was that it would be as simple as the float switch wired to the live of the pump and simply functioning as a switch to activate the pump when the water level rises.
However to my surprise there is a module in there, and I can't figure out what it would be doing there or why it might be needed and purpose it serves, so thats how I ended up here.
Can anyone shed some light on what this module could be doing or why it might be needed?
Thanks in advance!
