Fuses normally can survive like 1.3 - 2 times of the rated current for like a minute and a lot longer once you lower the current a bit. That multiplier usually is on the lower side for low current ratings and on high side for higher current ratings. Although I would not buy fuses from ebay, using safety devices from dodgy source is not smart. DC/AC does not matter for current they'll act. It matters for how high voltage and current they can break safely.
