Author Topic: Bad fuzes  (Read 1216 times)
Offline rdaggerTopic starter
    • Rototron
Bad fuzes
« on: July 09, 2018, 05:56:56 pm »
I bought an assortment of 5x20 fuses on eBay.  I hooked up an 8A fuse to a 120VAC circuit and plugged in a 13A hair dryer.  I ran it on high for about 2 minutes and the fuse didn’t blow.  My meter read 12.9A.
They look like AC fuses.  The fuse is stamped F8AL 250V.  I know AC and DC fuses have different ratings.  Could they be DC instead?
I guess I should have known better because the auction description described them as High Quality Fuze which seems applicable.
Offline schmitt trigger
  • Country: mx
Re: Bad fuzes
« Reply #1 on: July 09, 2018, 06:02:19 pm »
Fuses have so-called I-squared-T curves, and depending on the ratings, some can withstand an overload for quite some time.
Google: I2t
Offline Fsck
  • sleep deprived
Re: Bad fuzes
« Reply #2 on: July 09, 2018, 06:03:17 pm »
a fast blow 8A fuse will take way longer than 2 min to blow at 13A usually.
A fuse is designed to interupt serious overcurrent, not just a tiny overcurrent.
Look at the time-current chart for an 8A fuse in this datasheet as an example:
https://www.mouser.ca/datasheet/2/643/ds-CP-5sf-5sfp-series-1313110.pdf
"This is a one line proof...if we start sufficiently far to the left."
Online wraper
  • Country: lv
Re: Bad fuzes
« Reply #3 on: July 09, 2018, 06:14:09 pm »
Fuses normally can survive like 1.3 - 2 times of the rated current for like a minute and a lot longer once you lower the current a bit. That multiplier usually is on the lower side for low current ratings and on high side for higher current ratings. Although I would not buy fuses from ebay, using safety devices from dodgy source is not smart. DC/AC does not matter for current they'll act. It matters for how high voltage and current they can break safely.
« Last Edit: July 09, 2018, 06:16:36 pm by wraper »
The following users thanked this post: mcinque
    • Rototron
Re: Bad fuzes
« Reply #4 on: July 09, 2018, 07:10:20 pm »
Very helpful!
Thanks for taking the time to explain.
