Electronics => Beginners => Topic started by: gaddy996 on February 03, 2014, 08:21:10 am
Title: Bad power supply?
Post by: gaddy996 on February 03, 2014, 08:21:10 am
Hi, i have TLC L32m61AZ tv that wont turn, ive taken out the power supply, and im reading +20.21v on the +24v rail. Could this be the problem? If so what would be causing it?
Title: Re: Bad power supply?
Post by: Rigby on February 03, 2014, 01:32:01 pm
Could be.
Test all the electrolytic caps after looking for obvious signs of destruction.  If you have no way to test, power it on for a while and see if anything gets crazy hot.  Let us know what you find.
Post by: electronics man on February 03, 2014, 05:09:24 pm
Do you have an esr meter if so its the esr of the caps you are looking for and not the capacitance. And also test the resistance between +24v and ground
Post by: valentinc on February 03, 2014, 09:16:06 pm
      If you have an oscilloscope check the ripple on the +24V rail... If it's more than ~ 100 mVpp then certainly it's a faulty capacitor on that rail...
      Also, something that happened to me in the past with a power supply, was the voltage reference for the feedback circuit... Which wasn't working correctly, and that made a 12V power supply to output about 10V or so... Also check that...
Post by: gaddy996 on February 08, 2014, 07:18:51 am
Sorry for the late reply, i have test the rails with and without load, this is what im getting. And sorry there is no sign of any bad caps. Sorry i don't have an  oscilloscope :(
Without Load
12v Rail = 13.44
24v Rail = 20.36
With Load
12v Rail = 10.95
24v Rail =25.6
Are these results normal, i usually though voltage goes down with load?
Post by: electronics man on February 08, 2014, 10:50:04 am
They don't look good
Post by: valentinc on February 08, 2014, 01:42:16 pm
         No, they are not normal... It's normal for an unregulated power supply that the voltages drops with load... But most switching power supplies are regulated... (your's sure is, because the load of the circuits of the TV is not constant) Either by sensing the current in the primary of the transformer, either the voltage in the secondary, or both in many cases... Try to check the voltage reference in the secondary side, see if it's within specs, and that it's stable (regarding of the load current)... If there is no sign of bad caps, most probably they are ok...
         There are many possible causes like: the voltage reference, the optocoupler, the switching transistor... What IC does it use ?
Post by: gaddy996 on February 08, 2014, 10:44:30 pm
I think i have located the voltage reference IC in the power supply. Its a VIPer22A, is this the voltage reference IC? How can i check that is working?
Post by: valentinc on February 08, 2014, 11:50:31 pm
      The VIPer22A is the control IC, with integrated switch... Measure the voltage at pin3 (feedback)... It should be between 0V and 1V and it should be steady with a constant load...
Post by: gaddy996 on February 09, 2014, 12:03:15 am
Yeap im getting 0.6v DC, on that pin. Does that mean its fine? What should i try next?
Thanks Valentinc
Post by: valentinc on February 09, 2014, 12:11:01 am
       Does the decimals after 6 vary ? If yes, by how much ?
Post by: gaddy996 on February 09, 2014, 12:29:55 am
Its starts at about 0.605v without load. Once tv turned on (with load), it goes down to 0.456v and plays around between there and 0.725v. Sorry i didnt check it properly the first time.
Post by: valentinc on February 09, 2014, 01:23:02 am
        It varies quite significantly... Try to locate the voltage reference in the secondary side... Behind the transformer is an optocoupler, the voltage reference is connected to the "secondary" part of the optocoupler, the led to be exact... And then measure that...
Post by: gaddy996 on February 09, 2014, 01:53:16 am
I think i have located the voltage reference ic on the bottom side of the power supply. Could you verify which pins i need to test against?
The picture shows the ic in red and the optocouplers in blue.
Sorry i cant read the writing in the ic at all
Post by: gaddy996 on February 09, 2014, 01:53:56 am
That is the only ic on the secondary side btw
Post by: valentinc on February 09, 2014, 02:22:15 am
       The IC must be a TSM101... The output of the reference is at pin1 (with respect to pin4, which is ground)... It must be 1.24V
Post by: gaddy996 on February 09, 2014, 02:43:30 am
These are the readings im getting:
Pin 1 = 0v
Pin 2 = 0v
Pin 3 = 0v
Pin 4 = 0v
Pin 5 = 4.97v
Pin 6 = 4.97v
Pin 7 = 0v
Pin 8 = 2.456v
Does that mean this IC is dead or blown?
Post by: valentinc on February 09, 2014, 02:47:15 am
     Not necessarily... It may mean that it's not a TSM101 chip... TSM101 pin8 is Vcc, which should be a lot higher than 2.4V... Can you try to use some alcohol to clean the chip and see the markings ? Or is is scratched ?
Post by: gaddy996 on February 09, 2014, 02:54:37 am
Sorry i cant read it at all, the writing on the chip is really faint and unreadable at all. You can see very faint writing but its definitely unreadable. Is there any other way i could i identify this chip?
Post by: valentinc on February 09, 2014, 03:03:29 am
        I looked up for the TL431, a common voltage reference chip used in switching power supplies, it comes also in a SOP8 package, but the pinout does not correspond to what you have measured... Of course it can be identified... Try to google SOP8 voltage reference, but there are a ton of them... And not all are intended for this purspose... There are also precision voltage references in this type of package... If I find out someting, I'll let you know...
Post by: gaddy996 on February 09, 2014, 03:04:46 am
Alright thanks heaps valentinc.
Im just really keen on repairing this power supply
