Author Topic: Testing connection resistance on a finished assembly  (Read 783 times)
Offline OwenHTopic starter
« on: February 10, 2022, 09:58:12 am »
I have a 24v product that is essentially an intelligent power switch with 5 connectors on the output.  A microcontroller monitors voltage and load.  A PowerProfet load switch from infinion is used as the switch to the outputs.  All 5 outputs are tied together to the load switch.  The maximum current is 9 amps.
There are a number of difficult solder connections and crimp connections that I would like to have load tested after the PCB is assembled into its enclosure.
What I would like to do is build a test setup that can do the following:
- Calibrate the ADC and voltage divider resistors on the product being tested
- Calibrate the current sense function of the Profet power switch
- measure the voltage drop across the device under maximum load (To test for any issue with components on the PCB)
- measure the resistance of the 5 outputs individually (to test for a bad solder or crimp connection)
What I am proposing is to build a test device that can switch the input of my programable load between the various outputs of the device being tested.  I would basically build a MUX using a pair of MOSFETs for each output and then have a multichannel ADC that would measure the the voltage at the following places:
- Input to the device tested
- output of device before the 5 connectors
- output of each connector before the MOSFET MUX
This would be controlled by a microcontroller or maybe a raspberry pi.  The controller would be isolated from the MUX, ADC, and device being tested.
I realise I would need to calibrate out the resistance of all the wiring from the device being tested to the MUX and Programable load.
Questions I have:
-Does this seem like a reasonable approach or am I missing something conceptually?
-Would It be advisable to measure both the positive and negative seperatly at each connection? Or can I assume that if there is an issue with the negative side of the connector it will show up when I measure the positive side?
- What kind of protection might I need for the MUX, ADC, ect (maybe this is too broad of a question)?
Nothing is designed yet so I’m just trying to brainstorm possible ideas here.
Thanks!
Offline Terry Bites
Re: Testing connection resistance on a finished assembly
« Reply #1 on: February 12, 2022, 01:35:59 pm »
If you use a force-sense resistance (AKA 4 wire) measurement you dont need to calibrate out anything. You can build a super cheap adaptor for a standard DVM- eg https://www.maximintegrated.com/en/design/technical-documents/app-notes/1/106.html
Offline tooki
« Reply #2 on: February 12, 2022, 02:38:37 pm »
hello
read this doc: http://ygdes.com/LiIon/charge/AppNote106.pdf
it may be helpful for you
Literally the same thing someone posted 10 minutes earlier.
