I've designed a 3rd order chebyshev passive bandpass filter with 10% BW and center frequency of 10kHz. However, when I feed it a 10kHz sine wave to the input, it immediately gets severely attenuated, and when I measure the output of the filter it's practically gone.
Below is my circuit, and the simulated frequency response. The values are rounded from the real actual components values I measured with an LCR meter.
And here is my physical circuit.
I understand since this is a passive circuit there is going to be some loss, and at 10kHz it should be around -7dB.
My first problem is that the input signal is being attenuated by ~8.5dB, from 1Vpp to 142mVpp at the input of the filter. This is the node that connects from the 50 ohm output of my function generator to C1 L1 and C2. In simulation at 10kHz it should only be around -6dB, so I would expect around 250mVpp, and this seems way outside the margin of error.
The second issue as I stated above is that the output is pretty much 0 at 10kHz.
Above on the oscilloscope it autoranged to 200mV/div for the output (channel 2) and reports 48mVpp, but when zoomed in as close as possible it just shows noise with a very slight oscillation at 10kHz, I guess implying a tiny bit of the input is making it to the end.
Even considering component tolerance which I already accounted for in the simulation, one would expect the center frequency to still be somewhere around 10kHz. Therefore I did a sweep from 1kHz to 50kHz, and no matter the frequency the output was still gone.
I'm very perplexed by this issue. I've tried different components with the same values. I've tried building it on different breadboards. I've tried different oscilloscopes and probes, and the behavior is the exact same. Just in case anybody is wondering, the probes are 10x which are also matched to 10x on the oscilloscope.
I've tried a different topology where you have LC in series with the input, then LC in parallel to ground, the LC in series to the output, of course changing the values accordingly, but I still have the same issue.
All this leads me to believe I'm doing something fundamentally wrong, but I really can't tell what it is. I'm physically building the circuit the same as I've simulated, but the results are totally different.
Any help would be appreciated.
