Very big electronics newb here. I can solder, wire things up, etc, but the most complicated circuit i ever put together was a blinking LED using a 555, led and resister
. My projects usually side on the mechanical side of the fence (lathing, milling, etc), although i did rewire a whole car once, but thats getting off topic.
So im in the middle of a project that requires me to deliver a small, controlled amount of compressed air at the push of a pushbutton. I am planning on using
https://www.alibaba.com/product-detail/3-5mm-Flow-Bore-2V035-06_60748410126.html?spm=a2700.galleryofferlist.0.0.3aeb35c1LxatxG, which is a simple solenoid valve that opens when 12v is applied (easy). Power source will be normal batteries in series to get 12vDC. But I need it to only open once per push of the button. To open the valve again, the user must release the push button completely and press it again. And I need to be able to dial in how long the valve stays open per button push. Doesn't have to be digital or anything fancy, tuning a Pot would be good enough.
Everything i know how to do (which is
very limited (basically a 555, a potentiometer and a transistor) would cause it to pulse on/off/on/off or just stay open when the button is pressed (direct wire to the push button).
I dont expect a full blueprint (although that would be absolutely fantastic
), but just some help getting on the right track would be amazing. What components would I even need to do this?
