I am using the student edition of Multisim to learn basic electronics. A simple circuit with a 120vac 60 Hz supply and a 100 ohm resistor load shows the two figures below. With the Mulitsim scope on DC coupling all looks correct with positive voltage half waves. But on AC coupling, there is a shift in the peak (+) voltage and now it has a negative voltage component to it.
Is the negative voltage when AC coupled due to the reverse recovery time? As AC couple, I have changed the supply frequency from 60Hz down to as low as 2Hz and except for the timebase change, the sine wave voltages look exactly as for 60Hz. I read that for typical diodes the Trr is measured in ns or us.
Thanks in advance for the help.
John
