Author Topic: Satellite Modem 10/100 Ethernet Ports  (Read 485 times)
Offline rakeshm55Topic starter
« on: December 13, 2023, 05:40:23 am »
I am referring to attached modem
https://www.comtechefdata.com/files/datasheets/ds-DMD20.pdf
It has an optional  terrestrial interface 4 port 10/100Base T Ethernet port.
1. What is the purpose for having 4 ethernet ports? Are they just redundant ports used one at a time.
2. Is this a 4 port ethernet switch? Or are they four independent ethernet ports?
« Last Edit: December 13, 2023, 06:00:56 am by rakeshm55 »
Offline amyk
Re: Satellite Modem 10/100 Ethernet Ports
« Reply #1 on: December 13, 2023, 06:12:10 am »
It helps if you look at the actual manual:
https://www.comtechefdata.com/files/manuals/radyne/modems/mn-dmd20-20lbst.pdf
See Appendix J.
The following users thanked this post: rakeshm55
