Author Topic: BAT54 has different versions what they can be used for.  (Read 649 times)
Offline sairfan1Topic starter
« on: March 01, 2024, 09:07:59 pm »
Please refer to attached image BAT54 inside is shown, looks like device marked A can be used a Diode but what other versions can be used for?
Online ataradov
    • Personal site
Re: BAT54 has different versions what they can be used for.
« Reply #1 on: March 01, 2024, 09:20:04 pm »
They can be used as a pair of diodes. This is a really strange question. There are tons of schematics where diode arrangements like this are used.
BAT54C is a typical diode-OR circuit. BAT54S is a common clamping circuit.
« Last Edit: March 02, 2024, 12:17:56 am by ataradov »
Alex
The following users thanked this post: boB, tooki
Online Zero999
  • 0999
« Reply #2 on: March 01, 2024, 09:25:10 pm »
The BAT54 is a Schottky diode. The different part numbers indicate whether it's a single diode, or two, in various combinations.
The other versions can be used in any application two diodes are required, so long as they're joined together. For example two of the BAT54S can be used to make a bridge rectifier.
Fortunately the part numbers are easy to remember: A means common anode, C common cathode and  S series.
The following users thanked this post: boB, sairfan1
Offline newbrain
« Reply #3 on: March 01, 2024, 10:11:08 pm »
Another typical application for the series is creating a diode ring for a double balanced RF mixer.
Offline thm_w
  • Non-expert
« Reply #4 on: March 01, 2024, 11:47:28 pm »
BAT54C can be used to OR two power supplies together, eg USB and battery, into one output.
You can also always use one of the diodes and just ignore the unused part.
This is Beginners section, so its not really a strange question for someone with little experience.
The following users thanked this post: sairfan1
« Reply #5 on: March 02, 2024, 03:24:38 am »
these packages made me curious and I wanted to know what could be the reason. All those comments are really helpful. Thanks
Online ataradov
    • Personal site
« Reply #6 on: March 02, 2024, 03:34:59 am »
And if you arrange them by the use rate, it would be BAT54S, BAT54C, BAT54A, BAT54. And there is a huge gap between the first two and the last two.
The single version makes no sense to me. It is also available in a smaller 2-pin package, so there is no reason to use this package. And if you just need one diode, but already have any other type in the design, you might as well use that and eliminate a BOM item. The price difference between them is insignificant unless you need millions. But then smaller package is even cheaper.
Alex
Online SiliconWizard
« Reply #7 on: March 02, 2024, 04:05:10 am »
While the rationale may look puzzling at first sight, one use case would be specifically if, for some design you'd have 2 variants, populated differently on the same footprint, either as a C, D or the single one. Not that I have a specific circuit to suggest right now, but I guess that could be. Admittedly, for this particular need, if this is what was targeted, I'm wondering how the vendor could have determined there was a sizable market for that. Oh well.
Online amyk
« Reply #8 on: March 02, 2024, 05:35:50 am »
There is the possibility that the single variant contains one good diode and one bad diode on the same die.
Online ataradov
    • Personal site
« Reply #9 on: March 02, 2024, 05:41:04 am »
There is almost no chance of that. It is seriously not worth the time and logistics to keep track which diodes are half bad. And then you will have to bond to the same pin a diode on a good side, which complicates bonding process.
If you are not getting 99% yields on two diodes, you are doing semiconductors wrong. So, no matter what you will have to substitute with good ones.
Alex
Offline sleemanj
  • Professional tightwad.
« Reply #10 on: March 02, 2024, 06:09:05 am »
Maybe better thermal performace.
Does seem a bit weird though, if they were binning failures you'd expect to see all 4 possible single diode combinations.
Offline Shell Albert
« Reply #11 on: March 02, 2024, 06:20:28 am »
the two diodes pair is used under circumstances like this.
it's called diode gate logic.
