Author Topic: Panel mount potentiometer with a notch on it- how do I panel mount it  (Read 7433 times)
Offline SkippyTopic starter
I've bought a pot from eBay which is meant to be panel mount. I've also bought a box. I've drilled a hole around the right size, but the pot has a raised notch on one side. What am I supposed to do with it? Am I supposed to cut out a hole, and if so how? I guess it's to stop the pot spinning over time when the knob is turned.
E.g. this one, see the raised notch on the left. http://uk.farnell.com/jsp/displayProduct.jsp?sku=1760792&CMP=e-2072-00001000&gross_price=true&{copy:mckv}|pcrid|14164337469|kword|{keyword}|match|{matchtype}|plid|{placement}
Re: Panel mount potentiometer with a notch on it- how do I panel mount it
« Reply #1 on: August 28, 2012, 06:25:44 pm »
Use the template in the datasheet and a drill bit of the right size....... Or cut it off and have it spin in the box when the nut comes loose or somebody tries to wind it to 11.
Online Monkeh
« Reply #2 on: August 28, 2012, 06:32:00 pm »
Get a file. File out a notch in the box with the file.
Offline madires
  • A qualified hobbyist ;)
« Reply #3 on: August 28, 2012, 06:44:47 pm »
The quick and dirty solution: if the box is a plastic one, heat up the metal notch with your soldering iron and press the pot into the plastic (and through the hole of course :-).
Offline T4P
  • Country: sg
    • T4P
« Reply #4 on: August 28, 2012, 07:47:11 pm »
Fastest and Cleanest : Use a plier and twist it out
Offline krivx
  • Country: ie
« Reply #5 on: August 28, 2012, 07:57:04 pm »
I've cut off the tab in the past. As long as you use a locking washer and tighten things sensibly you don't need to worry about it spinning around.
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #6 on: August 28, 2012, 08:33:25 pm »
Cut off the tab, assemble the whole unit, fill the case with potting epoxy.  Guaranteed NOTHING will move ;D  ;D  ;D
Offline G7PSK
  • It is hot until proved not.
« Reply #7 on: August 28, 2012, 08:48:00 pm »
Rub some black felt tip or chalk onto the pin  and then push the pot into its mounting hole from the outside this will leave a mark as to where you need to put your hole or notch.Surest way to get the right position.
Offline notsob
« Reply #8 on: August 28, 2012, 09:42:11 pm »
If you don't want a hole showing thru the panel, mark the location for the tab and partially drill into the panel (ie don't drill all the way through), then trim (shorten) the tab to fit.
