I have a Harbor Freight cheapo float charger which I have used to maintain my motorcycle battery. The red light is on when the polarity is correct and the power is supplying the charger. However, when the power is disconnected (ie my grandkid pulled the extension cord out of the wall) the red light remains on and, over time, drained the battery. My thought is to use a diode on the positive cable to prevent the battery from back charging the float charger. First of all, will this work? Secondly, is it a good idea and thirdly, if the previous two questions are a yes, what type of diode should I use? Note: I probably don't need to tell you that I am dumber than a sack of hammer handles when it comes to electronics!
