Electronics => Beginners => Topic started by: JJ_023 on November 07, 2024, 11:30:23 pm
Title: Battery Holder for 10440 14500 16340 18650 20700 21700 26650
Post by: JJ_023 on November 07, 2024, 11:30:23 pm
I'm asking the communities help in locating a battery holder that has a sliding spring clip to accommodate a whole range of batteries listed in the title.
Most battery holders that I see for 18650 batteries are like the black one.  That is not something that I want.
I'm looking for something like the white one,  but a holder not a charger.  Something with an adjustable spring so it can be used with a wide array of different batteries and then has 2 wires to hook up to a bench power supply.
As a last resort I can make one but the time involved is just not worth it.
Any help and all suggestions are greatly appreciated.   Thank you.
Title: Re: Battery Holder for 10440 14500 16340 18650 20700 21700 26650
Post by: BILLPOD on November 08, 2024, 01:49:30 pm
Good Morning JJ_023, How about cannibalizing that EBL charger that you  show,
or one similar.   :-//
Post by: JJ_023 on November 08, 2024, 02:01:22 pm
That is a great suggestion.  I also have a machine shop so I can make my own.   But the time that all of that takes is just not worth it.  If something is commercially available it's probably going to be only a few bucks, I just can't find anything.
The closest thing that I found is a 4 wire  solution (see picture).   It would definitely work but it's just cumbersome to use and has to be constantly adjusted.  I just want a spring-loaded holder.
Post by: kripton2035 on November 08, 2024, 03:30:36 pm
this one is easyly adjustable, although it's not exactly what you're searching for...
https://www.gamry.com/cells-and-accessories/electrochemical-cells/universal-battery-holder/ (https://www.gamry.com/cells-and-accessories/electrochemical-cells/universal-battery-holder/)
(https://www.gamry.com/assets/Uploads/universal-battery-holder-ubh.jpg)
Post by: JJ_023 on November 08, 2024, 05:15:47 pm
Thank you for finding that.  That is a very robust design.  Made out of aluminum with ratcheting teeth for adjustment.  They use a nonconducting bushing to separate the terminals.   They incorporated a fuse holder.   Connections look goldplated.  It's a beautiful product for sure.  Have no idea what it costs but it should be pricey based on all of that.
However it's not for me.  I prefer the simplicity of a sliding mechanism with a spring.  Also this is bulky for the purpose that I am looking to use it for.  I am looking for something the size of that holder without the board or any of the other attached peripherals.
Post by: kripton2035 on November 08, 2024, 08:20:37 pm
I've searched for that also, and did not find any ! the previous idea to buy a simple charger and reuse the battery holder part is the best so far.
Post by: J-R on November 08, 2024, 11:48:07 pm
For just charging on the bench, I suggest using magnets.  Sticks to the battery and the alligator clips.
Post by: JJ_023 on November 09, 2024, 01:33:38 am
It's funny you would think something like this would exist.  If I go down that road I'll just create my own and machine it out of a nonconductive material with conductive inserts.
Post by: JJ_023 on November 09, 2024, 01:35:20 am
I think that's a great idea.   I have actually used this in the past.   I've even used rubber bands in a pinch.   But honestly all I really want is just a spring holder.
Post by: MrAl on November 09, 2024, 08:44:16 am
I wanted the same thing many years ago but could not find anything similar.  I ended up making my own.
Some of the cheaper battery chargers with a spring loaded slide are cheaper maybe you can find a cheaper one to modify.  It might be hard though to find something for all those battery sizes.  I only needed a few sizes and it was hard to find and never found one, but that was some 10 years ago haven't really looked since then.
Post by: JJ_023 on November 09, 2024, 08:36:05 pm
If nobody seems to be able to find them, including myself, I will just make one.  Probably make it out of aluminum with insulating inserts.  I dread doing this as I overcomplicate my designs and it takes me forever to finish.
Post by: MrAl on November 10, 2024, 01:39:06 pm
I made my with a strong wood base.  3/4 inch pine.  You can make several on one piece of pine.  Can't remember where I got the spring though.
Just keep it simple, and do some good measurements first.
Post by: JJ_023 on November 10, 2024, 11:00:51 pm
Hey thank you for the suggestions.  I usually will just model something in Solid Works first.  Then if I like the design I will machine everything to the specifications I come up with.
