Author Topic: LCR Meter U1733C Auto Identification Series-Parallel Mode  (Read 166 times)
Offline 2XTopic starter
  • Country: gr
« on: November 10, 2024, 09:11:53 pm »
Hello,
I would like to ask what means the Down and Up column for each frequency and range. For example, at 20 H range, it writes that uses Parallel Mode for Down and Serial Mode for Up in order to measure an inductor. What means by Up and Down. I can't understand what mode uses in order to measure an inductor at 20H range @100Hz .
According to the below article (generally speaking) “series equivalent circuit mode is used when measuring low-impedance elements (with an impedance of approximately 100 Ω or less) such as high-capacity capacitors and low inductances” and “parallel equivalent circuit mode is used when measuring high-impedance elements (with an impedance of approximately 10 kΩ or greater) such as low-capacitance capacitors and high-inductances”.
https://www.hioki.com/global/learning/usage/lcr-meters_2.html
Offline TimFox
Re: LCR Meter U1733C Auto Identification Series-Parallel Mode
« Reply #1 on: November 10, 2024, 10:06:00 pm »
It should be mentioned somewhere in the manual.
My guess (not having the manual) is that "down" and "up" refer to the aftermath of an auto-range switching near the boundary between decade ranges of inductance.
