Author Topic: Battery tester  (Read 1014 times)
Offline JaneTopic starter
Battery tester
« on: January 29, 2019, 08:30:46 pm »
Can anyone recommend a good battery tester for testing batteries in mobile phones and tablets and probably also in laptops?
Are any any rules for setting charging and discharging current?
Thanks
Offline FrankE
Re: Battery tester
« Reply #1 on: February 02, 2019, 07:40:57 pm »
In what sort of environment and for how frequent usage?
For storefront? Home use?
Offline soldar
Re: Battery tester
« Reply #2 on: February 02, 2019, 08:10:02 pm »
I guess it would make sense to discharge at the rate at which it is used in whatever device.  If it is a phone and it uses on average 250 mA then it would make sense to discharge at that rate and see how long it lasts.  And the same with charging.
