It seems what you bought should work in an "upside down" version of the BEAM circuit which exchange NPN and PNP transistors. Although this is kinda an off-the-cuff remark and I haven't tried drawing it out.
The original BEAM circuit:
Update: The two transistors in the original BEAM circuit form a discrete thyristor. Once the 1381's output goes high for even a little bit the PNP keeps base current flowing into the NPN even if the 1381's output goes low. This continues until the cap is depleted.
Here's a page on the two-transistor analogy for a thyristor:
https://www.electronics-tutorials.ws/power/thyristor.htmlIt shows the thyristor being triggered at the base of the NPN. But you can also trigger it by bringing the base of the PNP low. In this case you'd move the motor to the low side of the circuit.
