Author Topic: Mastercraft multimeter 52-0059-8  (Read 12349 times)
Offline sainbabloTopic starter
  • Country: pk
« on: October 12, 2016, 09:24:16 am »
Hi everyone,
Need help. The resistors 3,5,6 and 9 on this gadget Mastercraft multimeter 52-0059-8
bought some years ago in Halifax NS are busted badly
I cant read the color code.Any one having diagram please send me the values of these resistors
Will be very grateful Thanks
Offline Cliff Matthews
    • General Repair and Support
Re: Mastercraft multimeter 52-0059-8
« Reply #1 on: October 12, 2016, 12:39:43 pm »
CT sells re-branded meters - much better to post a picture of the pcb and, if possible, find the orig. mfg. and revision marks on it?
Also search the forum for just Mastercraft. You will see mfg. Colluck make the more recent ones.
Yours appears like this one:
http://www.colluck.com.hk/diyhp/9359/enus/c-25520/p-AAASX6AAGAABeT1AAj/Pocket_Size_Analog_Multimeter.html
edit: image HH2706
maybe they will have the schematic, but good luck!
« Last Edit: October 12, 2016, 12:43:33 pm by Cliff Matthews »
The following users thanked this post: sainbablo
« Reply #2 on: October 12, 2016, 01:01:07 pm »
If you reach a dead-end getting the schematic, try the main office - gotta love that Canadian flag (flapin-in-the-breeze..) :-DD
http://www.tradeeasy.com/supplier/8117/colluck.html
Offline Audioguru
« Reply #3 on: October 12, 2016, 02:40:14 pm »
I think it is time to replace the old analog meter with a modern digital multimeter. Can't you afford ten dollars?
I used my expensive Fluke digital multimeter in the lab and at home then I bought a cheap Can-Tire digital multimeter so I could measure voltage and current at the same time. They both have the same accuracy.
« Reply #4 on: October 12, 2016, 04:27:35 pm »
..Can't you afford ten dollars?
He's in Pakistan mate.
  • Country: pk
« Reply #5 on: October 12, 2016, 05:32:08 pm »
Hi Every one
Thanks a lot for your helpful posts
Cliff, it is same as in your first picture.I shall follow up your
suggestions
Yea, got to love that Canadian Flag any time any where (my adopted home)
To Audioguru, this gadget has sentimental value for me, it is dainty, handy and serves the purpose
though lot of Chinese stuff is available locally but  I would rather stick to trusted brands as long
as it last
Thanks again
Offline Paul Moir
« Reply #6 on: October 12, 2016, 10:27:28 pm »
I think I'll be seeing one of these meters on Saturday, coincidentally about an hour's drive from Halifax.  If someone doesn't get you a picture by then I'll take one.
Online macboy
« Reply #7 on: October 12, 2016, 11:39:21 pm »
I hope these can help you out.
The following users thanked this post: Cliff Matthews, sainbablo
« Reply #8 on: October 13, 2016, 01:38:14 am »
Macboy, you da  8) man.
God I love this forum! So much knowledge and so many good people. I always thought Dave's chest was big cause he works out.. :-DD
Now I know it's because this place makes him proud to be alive!  Sainbablo, I notice this was your first forum post, welcome!
  • Country: pk
« Reply #9 on: October 13, 2016, 05:21:53 pm »
Thanks Cliff.
It has been  to my fortune that I am mingling with people devoted to further the cause
of education. I can sense friendliness and an urge in these pages to help each other for the greater good
of community.
Regards
sainbablo
  • Country: pk
« Reply #10 on: October 13, 2016, 05:59:17 pm »
To  macboy
Lot of thanks for the pcb picture
Here the values  I have been able to decipher
These resistor have 5 bands and on Electrodroid App 5th band doesnt show up on some.
R3  Brown      White    Yellow   Mauve   Brown           1.94k
R5  Brown      Black     Black    Green                        10M
R6  Brown      Brown   Yelow    Brown                        1.14k
R9  Brown      Grey      Black    Blue                           180M
Perhaps if you can double check before I solder the replacement resistors will be  real help
An other tricky question. If resistors of exact value are not available what is the % of leeway if any, resistors
of higher or lower values can be used.
The gadget is to be used I routine AC DC volts measurement and resistance mainly in low voltage
radio related repair
Thanks
Offline Macbeth
« Reply #11 on: October 13, 2016, 07:26:59 pm »
I think you are reading the colour codes backwards. The common brown band to all of them means they are 1% tolerance.
  • Country: pk
« Reply #12 on: October 14, 2016, 06:59:20 am »
Thanks I will do home work again
  • Country: pk
« Reply #13 on: October 26, 2016, 09:12:10 am »
Hi everyone
Here is the reply from Mary-colluck,  hunghey@126.com, to my post.
The original site is mentioned by "cliff"
R3      19.4K
R5      950
R6      1.14K
R9      46
  • Country: pk
« Reply #14 on: October 26, 2016, 09:21:28 am »
Hi
If the resistors of exact value are unavailable would a knowledgeable person suggest
nearest values? Thanks
Offline WaveyDipole
« Reply #15 on: October 26, 2016, 10:34:49 pm »
You might have to make up the values by putting a couple of resistors in series or parrallel. For example:
19.4k = 47k + 33k in parallel should be pretty close
950 = 620 + 330 in series
1140 = 820 + 220 in series
46 = 22 + 24 in series
« Last Edit: October 26, 2016, 10:37:07 pm by WaveyDipole »
Offline SkyMaster
« Reply #16 on: October 27, 2016, 10:51:12 pm »
So, Mastercraft is the house brand name of Canadian Tire.
But, a Mastercraft branded product, with the correct Canadian Tire part number can be found in Pakistan.
I also saw, on a different forum, pictures of Mastercraft tools (some still in their original packaging) that were available in the Philippines.
This is intriguing.
  • Country: pk
« Reply #17 on: October 28, 2016, 02:39:19 pm »
Thanks Wavey,
But the size of pcb limits innovation. Do suggest way out.
  • Country: pk
« Reply #18 on: October 28, 2016, 02:58:23 pm »
This is intriguing.
I will check again locally but I am sure Canadian brands need presence here provided it can compete with Chinese products price wise.
Before partition of the sub continent into Bharat( now India) and Pakistan in 1947, it was almost exclusively British followed by German and other
Europeans countries who held sway in this region.These products  lasted for decades. No exaggeration. But times have changed.The Chinese products From Canadian Tire, I have plenty from a store at Quinpool Road Halifax NS ,are much superior.Thanks for info.
Offline RoTaTech
« Reply #19 on: November 28, 2016, 04:36:15 am »
According to my (second) ohmmeter,
R3=270k  R5=590r R6=1.14k R9=47r. My eyes at this moment are not seeing the colours, but if you still need, I will try to have a look when it is sunny tomorrow.
« Last Edit: November 28, 2016, 04:44:29 am by RoTaTech »
Offline eshirley
« Reply #20 on: December 15, 2017, 02:29:08 am »
I saw this post, looking for the correct resistor to replace on my Mastercraft Multi-meter.  The picture was almost perfect.  The resistor R11 is broken and need to replace it.  Is it possible to get a picture of the whole thing?  Bought a digital but have to fool around with the leads every time to get it to work!
