Author Topic: using on semi C5 process with electric  (Read 1271 times)
Offline kzomranTopic starter
  • Country: eg
« on: May 25, 2019, 10:05:01 pm »
Hello,
i am trying to use electric vlsi tools to make a chip with on semi C5 process to submit it to mosis for manufacturing
my question is for On Semi C5 process
>what is the sheet resistance of n-well resistor and what is the minimum width
>also what is the sheet resistance of poly1,poly2 and minimum width
>when we say sheet resistance do we mean one lambada width and one lumbada length that is w=0.3 um l=0.3 um  or what are the dimensions of the sheet
>when designing a capacitor with poly1 and poly2 so what is the capacitance of the area of each poly
> and since poly1 has different capacitance per area than poly2 so do i have to use different areas of poly1 and poly2 to have matching capacitance
thank you
Offline jmelson
Re: using on semi C5 process with electric
« Reply #1 on: May 25, 2019, 11:39:38 pm »
Hello,
Are you sure this process is still available?  They seem to have only one run this year, and not a lot of time left to submit.
Do you have the design kit?  If not, your chances of producing anything are essentially zero.
You can get the design kit for the process from MOSIS, but there is a LOT of paperwork involved.
But, it will have very detailed information on these parameters, although they may be encoded into device models.  It probably wouldn't be hard to extract this from the models, but once you have models you may not actually need these parameters.
Jon
  • Country: eg
« Reply #2 on: May 26, 2019, 10:01:49 am »
thanks i got the idea now. the first were to start is to sign NDA with On Semi
Offline amyk
« Reply #3 on: May 26, 2019, 06:37:03 pm »
You can find some of the info here: https://www.onsemi.com/pub/Collateral/C5-D.PDF
