Soldering advice please
I've had a bit of a practise with my microscope and enamelled wire, some parts went OK, some didn't.
I first tinned the end of 12 pieces of wire, with iron on 400c (750F) and dipping end of wire in flux, loading the iron with solder, and passing the end of the wire through the solder that's on the iron (as per a couple of youtube vids). This worked well in most cases.
I then turned my iron down to 300C (570F)
Then I removed the solder points from a few holes in a bit of prototype PCB, mounted one side of the ic so that the legs I'm soldering onto are between the holes I just removed.
I then put flux onto the right hand leg, added a bit of solder, even with the wire in the tweezers, spent what felt like an eternity getting it to solder onto the pin (far too long, would melt the hdmi port), but hey, it was my first one and I'm learning.
I then realised I should start at the left hand side so that I'm not bringing the iron over ones I've already done.
I fluxed all the pins, dragged the solder across them all,. that seemed to work fine.
then I fluxed the first pin, put wire in tweezers, this went straight on with zero problem. The rest I really struggled with, I THINK part of it was because none of the legs on this side of the IC were soldered down, hence when I touched with the iron, the leg moved a fraction down, when I removed the iron, the leg moved a fraction up.
Anyway, I eventually soldered all 12 on (refluxing for each wire)
Then I decided to solder the other ends to the PCB. I went from right to left, fluxing the PCB, soldering the PCB, fluxing again, then soldering the wire to it, then cutting the remaining wire. This worked perfectly to begin with.
Then I snapped one of the wires, while trying to repair it, I removed the one to the left of it by accident. At this point I thought I would ask for advice.
I took a photo through my microscope (first pic)
I thought I'd clean the PCB then photograph again, hence cleaned the joints of the IC as gently as I could with Isopropyl and cotton buds (q tip), but even going as gently as I could, I snapped the 4th wire in from the right. This wasn't the solder joint breaking, it's the wire snapping, it's about as strong as a human hair (second pic), I also see getting a bit of flux on the top of the IC and removing with Isopropyl, removes the IC part number.
And the final pic is a pic of where I soldered the other ends to the PCB (the one that looks like it's going underneath the others is the one that snapped)
I'm using 0.1mm (38 AWG) enamelled wire as that's all I have, would going down a few grades be a sensible move, making the wire stronger?
I just wondered after looking at my attempts, whether anyone has any advice before I try again? The legs on the HDMI port are going to be smaller than the legs on this IC. Or is it just a matter of practice, practice, practice? I have a load of cheap hdmi ports turning up tomorrow to practice with.
Wish I could take a vid of me trying, but only have a cheapish microscope (Swift S41-20) , so please excuse the photos, hard taking a pic through one of the lenses
I have some decent gel flux arriving tomorrow, that will probably be better than the liquid flux I used today.
I've been using the smallest soldering tip I have (0.8mm chisel tip, Hakko T18-D08)
Many thanks for all your help, I will get there eventually
