Aluminium is much lighter than copper.
It makes sense in a speaker voice coil.
Soldering aluminium is difficult. You will need a special flux.
Cheers, didn't think about the weight, makes sense.
I did have a go at winding a voice coil, as said cardboard tube, I used a light coat of varnish to secure the coil after I wound it.
Also , if you wind it whilst in place on the magnet, might be a good idea to put some grease proof paper between magnet and tube as a shim, if the coil pulls the tube in tight and binds, removing the shim gives you back some clearance.
