Author Topic: whats the opamp you always end up using? and why?  (Read 16274 times)
Offline little_carlosTopic starter
« on: April 07, 2016, 04:09:00 pm »
I know there's hundreds of different opamps in the market, one for each purpose or situation, but admit it, everyone has a favorite, right now, and since i started with electronics, the opamp i always end up using is the lm358, its cheap, has two inside, most of the time by inertia always use it, whats the one you always think at the first and why?
Offline Audioguru
Re: whats the opamp you always end up using? and why?
« Reply #1 on: April 07, 2016, 04:44:34 pm »
I never use an LM358 because it is noisy, it produces crossover distortion and it has trouble with high output levels above only 2kHz. Instead I use the MC3417x single, dual and quad that have the same low power supply current per opamp, the same inputs that work all the way down to 0V and the about the same output voltage swing. But the MC opamps do not produce crossover distortion and work well with high output levels to 35kHz.
Cheap? Cheep, cluck cluck. Opamps are inexpensive.
Offline brabus
« Reply #2 on: April 07, 2016, 05:06:54 pm »
Interesting! I also use always the same LM358, I bought a bunch of them many years ago and it's just fine.
The main (only) reason why: common mode input range down to 0V.
But I will try the MC3417x fr sure, thanks for the hint!  :-+
Offline rolycat
« Reply #3 on: April 07, 2016, 05:56:47 pm »
Are you sure you don't mean MC3317x?
If so, they seem to be hard to come by in DIP, which may be important for beginners.
Offline Delta
« Reply #4 on: April 07, 2016, 06:57:56 pm »
LM358 for DC stuff.  It can ride down to 0v on a single supply, and I have loads of them.
TL074 for audio stuff.  They sound fine to me, and I have loads of them.
Offline rstofer
« Reply #5 on: April 07, 2016, 07:11:57 pm »
TL081 for dual supply analog computer stuff.  About to change to something else.  AD4771?
TLV247x for single supply.  Available as 1,2 or 4 devices per package
Check graph on page 4.5 (Figure 4.7): http://www.cypress.com/file/65366/download
Look at the performance of the LM358
See first paragraph on page 4.6
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
« Reply #6 on: April 07, 2016, 07:14:57 pm »
I'm a conservative (audio) designer.
I try to use always dual units (most of the times the cost less than singles) and don't like quads because their supply pins (v+ and V-) are on the reverse sides of the chip, so:
- if your PCB has straight power tracks, the quad chips is rotated 180° respect the dual : not nice to see and not liked by those who will mount the PCB.
- if you want to have all chips pointing in the same direction (a board layout must be elegant) you must twist the power tracks..
TL072 for unity gain circuits and tone controls, and NE5532 when low noise or high output level are needed.
JRC4580 can be a good replacement for NE5532.
If you need better noise or higher output drive,you can always parallel two or more amplifiers..
FET inputs are better when a potentiometer is connected to OP-amp input because the lower input current make the pot less noisy.
If I need a low cost quad (not on audio signal, but for secondary function, such as comparators for level indicator LEDS) I use LM324.
I've tested many others, but never switched because of:
a) single source and
b) higher cost or problematic availability
c) not a real improvement in performance
When I worked in industrial controls, the needs where different: first of all thermal stability (then OP07 was the king) and sometimes LM358.
You'll have problems if you use a TL072 in a thermocouple amplifier. Guaranteed.
best regards
« Last Edit: April 07, 2016, 07:32:46 pm by ciccio »
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
Offline Lovely_Santa
« Reply #7 on: April 07, 2016, 07:24:56 pm »
Nowaday there are more than enough tricks to make an smd IC to a DIP package..
I quick searched around:
This is for example a solderable PCB for a SOIC8 to a DIP8...
I know, maybe you don't want to solder, or want to use it multiple times for multiple IC's.. They have also this for example, just the same, without soldering...
English is only my 3th language, so don't tell me my english is bad, becose I know that, I try to do what I can...
Offline rolycat
« Reply #8 on: April 07, 2016, 07:39:54 pm »
I have a bunch of those. But not all beginners are confident enough to solder SOICs.
That's for a PLCC, and even then it's $22. Have you seen the price of SOIC8 adapters that don't require soldering? They are more like $250. Well out of reach of a beginner who just wants to experiment with some inexpensive op-amps.
Offline forrestc
« Reply #9 on: April 07, 2016, 07:50:10 pm »
Typically, I end up with a MCP6004 for my mixed signal projects:
Rail to rail in and out, 1.8 to 6.0V Vcc, low iQ (100uA typ), industrial temperature range, decent enough other specs.  < 50 cents qty 1, etc..  If I need a bit better Vos at the expense of iQ, I switch to a MCP6024.
Offline dentaku
« Reply #10 on: April 07, 2016, 08:00:23 pm »
I always end up using the LM358 for simple stuff because it swings down the bottom rail. For stuff that uses +/- power supplies I don't mind using the TL082 or 072 even though they're also ancient parts. I have no need for fancy OpAmps though.
I recently got some MCP602 and MCP6004 (quad version of the MCP6002) and they're useful as replacements for the 358 in circuits that don't need more than 5V.
The MCP6002/4 is nice because it's rail to rail IN AND OUT unlike the MCP602 which I think has an input range that doesn't quite reach the top rail.
You can get free samples from Microchip's website too.
Offline poorchava
  • Troll Cave Electronics!
« Reply #11 on: April 07, 2016, 08:05:53 pm »
For general purpose stuff in single-supply world MCP6001/2/4. The same in dual supply circuits I do with TL08x. For precision applications OPA2376, OP07,  MCP6V02 come to mind.
Sent from my HTC One M8s using Tapatalk.
Online Zero999
  • 0999
« Reply #12 on: April 08, 2016, 08:02:06 pm »
Whether the TL072 is more or less noisy than the NE5532, depends on the circuit.
Although the input voltage noise for the NE5532 is lower than the TL072, it has higher bias currents and a higher input noise current. If the input impedance is high (above about 25k), the NE5532 will be more noisy than the TL072.
It's best to use the TL072 when a high input impedance is desired and the NE5532 for a low input impedance amplifier.
http://www.ti.com/lit/ds/symlink/ne5532.pdf
http://www.ti.com/lit/ds/symlink/tl071.pdf
Offline Messtechniker
« Reply #13 on: April 09, 2016, 05:10:29 am »
Exactly.
Yours - Messtechniker
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
The following users thanked this post: Spike
