Hello everyone, I am still a beginner in designing boards and recently I created my first board with USB and it didn't go as smooth as I planned.
I designed a board with USB and ended up messing up with the USB port pinout. I tried to work around it and soldered a wire directly to the CH340, as attached. In my board, there is a FM radio module, and every time I use the radio to transmit, it creates noise in the USB 5V pin and it can go up to 5.5V, which according to the datasheet is out of the range of the normal operating mode of the CH340.
This also happens when I use my handheld transceiver nearby the USB connection. Is it safe to assume that this is only caused by my poorly made USB cable I soldered directly to the PCB?
Is there any improvement that I can add to my USB port circuitry to reduce impact of RF interference from my radio to the USB connection? What I have tried is adding a 10nF capacitor I have laying around and ended up making the oscillation worse.
The rest of the circuitry works fine, the only issue is the USB loses connection in presence of RF signal nearby.
Thanks for your input
