Author Topic: PCB design cost calculations  (Read 1194 times)
Offline Vindhyachal.taknikiTopic starter
« on: July 17, 2016, 03:22:12 pm »
What is most used practice for PCB design cost calculation. I have designed a 310 mm x 170 mm board.
Below are specs:
Total number of pins: 899
Pins in a net: 899
Not connected pins: 0
Test pins: 0
Jumpers: 0
Total number of vias: 185
Total number of connections: 651
Unrouted connections: 0
Completion: 100%
Total number of parts: 285
Total number of nets: 253
PCB size: 310mm x 170mm
No of layers: 2
Offline matseng
    • My Github
Re: PCB design cost calculations
« Reply #1 on: July 17, 2016, 03:32:50 pm »
Eh?   Maybe the number of hours worked on the project times your desired hourly salary?
The following users thanked this post: Kilrah
