Author Topic: Transformer replacement wiring question  (Read 559 times)
Offline CramboneTopic starter
« on: April 17, 2022, 11:52:32 am »
Hello all, I’m installing a new transformer and when looking at the Hammond Data sheet compared to the original schematic how would I cross reference the wiring color from old to new? They show a black dot on the original transformer schematic on the center tap but on he Hammond data sheet the black dots aren’t on the center tap?
Offline bob91343
Re: Transformer replacement wiring question
« Reply #1 on: April 17, 2022, 04:50:39 pm »
 Just overlay the Hammond unit on the original.  The connections are shown in the correct positions.
« Reply #2 on: April 17, 2022, 05:25:32 pm »
Thanks Bob that’s what I assumed as a center tap is a center tap per the drawings.
Andrew
Online Ian.M
« Reply #3 on: April 17, 2022, 05:57:34 pm »
I agree with Bob.
Err. *NO* its not a center tap on either the original or replacement diagram, because it isn't at the center of the winding with equal turns count either side of it.   Its a 'boost' tap that increases the secondary voltage when the switch is in SSB mode by removing a small part of each primary winding from the circuit, increasing the turns ratio.
« Last Edit: April 17, 2022, 05:59:33 pm by Ian.M »
