Author Topic: What is a spark gap, and why we need it on a PCB?  (Read 31426 times)
Offline bruce0126
Re: What is a spark gap, and why we need it on a PCB?
« Reply #25 on: August 04, 2017, 11:23:28 pm »
I know this is an old topic, but I'm just wondering why the solder mask should be removed on the spark gap?  The relative permittivity of solder mask is higher than air, so doesn't the solder mask actually makes it easier to arc over?
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #26 on: August 05, 2017, 12:56:53 am »
It could exhibit partial discharge, but then that discharge moves the voltage across the dielectric, and no further action results.  In other words, the tiny capacitance of the air gap (~0.05pF?) discharges, rather than the full load current.  It's like the static crackle when rubbing a balloon on hair.
If this happens enough times to cause both solder mask layers to break down, then a proper arc can start.  Since the solder mask thickness is highly variable, this could be many kV more than intended!
Not that spark gaps are at all well controlled to begin with, but that's just making bad to worse. :)
It's worse still when you consider the second strike: the solder mask has been pierced, so now it's only an air gap.  Except a small amount of solder mask has been carbonized, and more on each strike after that.  Rapid tracking ensues, and you get a glowing burning ~short circuit. :-BROKE :scared:
Seven Transistor Labs, LLC
The following users thanked this post: bruce0126
Offline AzharTopic starter
    • Youtube Channel
« Reply #27 on: August 05, 2017, 01:58:10 pm »
Dave made a video about spark gaps and here is a link in case someone didn't watch it :)
