I'm trying to set up my BenQ W1070 projector from the corner of the room, because I can't position it on the opposite wall from where I want the screen. But, because of the way it's positioned, the image looks crooked, and isn't a perfect square/rectangle. Is there some setting or something that I can use to adjust the screen that will fix this?
Also, I'm trying to adjust the position of the screen (not the projector itself) but the option called "position" in the "display" tab of the menu is grayed out, and I can't select it. What can I do about this?
