Author Topic: Best Budget Soldering Iron?  (Read 11570 times)
Offline chikenTopic starter
  • Country: hr
« on: April 10, 2019, 08:08:08 pm »
Hello,
So my soldering iron fell apart, mainly because of my fault, it had some tought time with me, it was a good soldering iron RIP :')
What do you guys could reccomend, which soldering iron to buy?
One with variable temperature ofcourse.
Main use would be electronics, but also something beefier parts too so wouldnt go below 40w.
Now the price might be "funny" but wouldnt go above 35$, well my wallet does not share same enthusiasm as i do about this kind of stuff :')
Offline stj
Re: Best Budget Soldering Iron?
« Reply #1 on: April 10, 2019, 08:24:56 pm »
bakon 950d with a T12 handpiece - NOT T13.
search the forum for bakon - lots of info.
Offline Cliff Matthews
    • General Repair and Support
« Reply #2 on: April 10, 2019, 09:26:03 pm »
Save money and provide your own 16-24v@3a PSU - $34 might work for you..
The following users thanked this post: WattsThat
Offline Shock
« Reply #3 on: April 11, 2019, 04:13:18 am »
The tip length on that last iron is a joke.
Here is another I found while looking for the old style T12 handle.
« Last Edit: April 11, 2019, 04:23:43 am by Shock »
Offline Shock
« Reply #4 on: April 11, 2019, 04:28:44 am »
Here is the Bakon one notice the difference?
« Reply #5 on: April 11, 2019, 04:50:08 am »
You're right.. but OP is limited to $35 (usd??) Power supply apart, can he/she get the good handle and controller alone?
Offline Shock
« Reply #6 on: April 11, 2019, 05:02:04 am »
Here is a Baklon 950D with the T12 iron for $37.59 with free shipping. Would be nice this iron on the other controller, on a non Chinese power supply, I guess that is called a Hakko FX951 heheh.
https://www.ebay.com/itm/121841641856
Offline Mp3
« Reply #7 on: April 11, 2019, 08:58:23 am »
That Bakon looks pretty neat! I may pick one up just because the price is so low.
You can get a TS100 for as low as $35 or $40 from China, and you probably already have a DC power supply around between 12 and 24 volts, so just use that with it, it's a really neat iron. I haven't used it much, but after using it  a few times it's quickly becoming a favorite.
High school graduate
Offline Psi
« Reply #8 on: April 11, 2019, 09:23:40 am »
These are pretty good, i know two people who have one.
Doesn't come with a stand though, but you probably still have one from your old iron
https://www.aliexpress.com/item/138x88x38mm-Digital-Soldering-Iron-Station-Temperature-Controller-EU-Plug-Temperature-180-435-Degrees-T12-Handle/32692999653.html
Offline Mp3
Offline Psi
« Reply #10 on: April 11, 2019, 09:55:26 am »
Is that or the 950D notably better than this, which i can get shipped within the usa for $22?
https://www.ebay.com/itm/YiHua-936-Rework-Soldering-Station-SMD-Desoldering-Solder-Iron-w-Stand-110V-US/381444146894?epid=1047266892&hash=item58cfd7c6ce:g:7ZMAAOSw0jFZpMkP&frcectupt=true
The 936 uses the older 900M style tips which are shit.
You want something with the tip+heating element in one block, like T12 on 950D or the one i posted.
The old tip style has a small air gap between the element and the tip which makes the thermal characteristic total shit compared to the new tip+element designs.
Think of the old 900M style tips like a computer CPU without any thermal compound between the cpu and heatsink.
Its shit.
« Last Edit: April 11, 2019, 09:59:55 am by Psi »
The following users thanked this post: Mp3
Offline Shock
« Reply #11 on: April 11, 2019, 10:27:06 am »
The Hakko 936 clone stations use a 900M/T18 style tip which screws onto the iron over the heater, the Hakko FX951 clones (BAKON, KSER etc) use a T12 style cartridge tip which has a heater built in and is easily swapped. The TS100 may come with no power supply and has a bastardized T12 style cartridge and uses a hex locking screw. The other clones mentioned look like the iron from a Hakko 936 clone with a T12 cartridge sticking out, they are an absolute abomination.
See these, this what the Metcal/Thermaltronics/Pace/Hakko (name brand irons) actually look like. Now go back and look at the Chinese Quicko and DSK stations shown and pay close attention to the length of the T12 tip sticking out. The iron in the bottom right of the photo is a genuine Hakko FM2028 with a T12 tip.
Here is another view of the Bakon 950D, I don't own one of these (wanted something better and non Chinese) but plenty of people have brought them. As I mentioned though above, the ideal mix for me is a Bakon iron (handpiece) a T12 clone controller (I believe KSER had updatable firmware) and a non Chinese power supply. The KSER iron looked ok but I read something about quality issues.
« Last Edit: April 11, 2019, 10:42:34 am by Shock »
The following users thanked this post: mauroh, Cliff Matthews, Mp3
Offline Mp3
« Reply #12 on: April 11, 2019, 10:33:05 am »
Point taken, thanks!
It seems to me from what i can tell the difference between t12 and t13 for the 950d is only length of the iron part itself.... is this true? I watched the russian video with translated subtitles and did some more googling but from what i understand its just length?
Offline paulca
« Reply #13 on: April 11, 2019, 10:33:19 am »
+1 For the TS100
Offline Shock
« Reply #14 on: April 11, 2019, 10:59:34 am »
I updated the end of my last post.
Length of the iron not so important. You want a smallest distance between the end of tip and the lowest point where you can comfortably grip (working distance). I'm not saying go rush out and buy a Bakon but hopefully you see the point I'm making.
Regarding the clone T12/T13 difference I can't remember the specifics but the T12 is the more popular cartridge. It's possibly for the above reason the iron supplied with the T13 makes the tip stick out further.
« Last Edit: April 11, 2019, 11:26:33 am by Shock »
Offline ebclr
« Reply #15 on: April 11, 2019, 11:24:47 am »
You can't change a hot probe without burning yourself, I would opt with the long ones instead of this short one
Offline Shock
« Reply #16 on: April 11, 2019, 11:38:14 am »
Most modern cartridge soldering stations are designed to have short tip working distances and can be swapped easily while 400C/752F. You use the provided heat resistant silicon pad or specific brands have an additional way of doing it. For instance Pace uses a tip tool, JBC uses their iron stand, Hakko uses the plastic tip sleeve.
You can buy Chinese silicon tongs on Ebay for $1, no burns.
« Last Edit: April 11, 2019, 12:52:59 pm by Shock »
Offline GreyWoolfe
  • NW0LF
« Reply #17 on: April 11, 2019, 11:39:15 am »
MP3, here is a question for you.  Do you plan to do a lot of soldering or occasional soldering?  If you plan to do a lot, it behooves you to save your pennies and buy a real and proper name brand unit with OEM tips.  There will be no disappointment there.  Don't be afraid to look at the used market, that is how I have my Metcal MX-500.  If your use is occasional, the Bakon that Shock linked might be a good choice if you have a power supply on hand but I will still recommend OEM tips.  They will simply outlast and out perform the $2 Chinese specials.  My dearly departed father always said that you buy your tool right and only buy it once.
Psi, I think you are being a bit hard on the 936/900m style.  I had a real Hakko 936 for about 7 years before upgrading.  It spent 2 years of its life replacing capacitors on Dell and ELO touch screen monitors for the company.  Granted, you can't solder 2 4" pieces of copper PCB together but for basic soldering it was awesome.  I had chisel tips from 3.2 mm down to .8 mm that let me solder 0603 passives and SOT23 components on SMD practice boards.  The limiting factor is finding OEM in a configuration you want.  There is a greater selection of T12 in OEM and clone.  By the way, I sold it to a ham club member and she is quite happy with it
« Last Edit: April 11, 2019, 11:46:11 am by GreyWoolfe »
Offline Psi
« Reply #18 on: April 11, 2019, 11:47:13 am »
I spend 10+ years of my life using irons that run 900M tips and i did lots successful soldering with them too.
It's not so much that 900m itself is shit, you can get the job done with it.
So maybe i should rephrase.
It's that 900M is shit once you have used a really good iron and then go back to it :)
My thermaltronics TMT-9000 totally ruined me, i just can't use a 900M without going "hm.. why is this iron taking so long to solder this part? oh thats right, 900m tip"
« Last Edit: April 11, 2019, 11:49:56 am by Psi »
Offline GreyWoolfe
  • NW0LF
« Reply #19 on: April 11, 2019, 12:03:13 pm »
We can agree on that.  There was a huge difference between the 936 and the FX-951 that I upgraded to.  When I added the Metcal MX-500 for a ridiculous price, that just gilded the lily. ;D  I couldn't go back either.
Offline Psi
« Reply #20 on: April 11, 2019, 12:32:42 pm »
I was lucky to get in on a special offer for my thermaltronics TMT-9000
They had a special trade-in deal.
You got the TMT-9000 station for ~AUD$450 and they gave you 20 different tips for free.
The tips are worth like $40 each so really really good deal.
Since it was a trade-in i had to surrender a soldering station to them as part of the deal.
I wish i still had a picture of it, i gave them this really tiny DSE brand station.
Like a 3x3x3 inch cube and plastic toy style iron pencil.
It still worked and said "soldering station" on it but was such a toy and a piece of junk.
« Last Edit: April 11, 2019, 12:34:30 pm by Psi »
Offline Shock
« Reply #21 on: April 11, 2019, 12:35:22 pm »
Got to remember as well they got a little better performance out of the Hakko FX-888D and T18 tip (according to Hakko) but as a sub $100 non Chinese station, with decent tip selection, if you use that criteria it's about the best thing going.
Who was this with?
Offline Psi
« Reply #22 on: April 11, 2019, 12:41:51 pm »
i'm not actually sure, somewhere in Australia. A friend told me about it as he was getting one too.
We are in NZ and arranged to get the stations shipped here and our trade-in stations shipped to Aus.
From memory the deal required more than 10 people or something.
I dont remember all the details though
Offline Mp3
« Reply #23 on: April 11, 2019, 12:53:23 pm »
Not soldering constantly, somewhere between occasional and whatever the level behind "a lot" is though 8)
I was looking to replace the FX888 i've had for about 8 years, since i have broken 3 handles on it and wanted something else, then i got the TS100 which i absolutely love so far, but i wouldn't have considered it if i was doing tons of soldering and working all day with it. For doing 5-15  minutes of soldering hooked up to a battery to solder in weird places easier, it's a lifesaver.
I actually had a pretty difficult time finding the 950D with the T12 handle, seems like most sellers outside of a few on ebay all sell it with T13 handles, i would definitely use OEM tips though! I was interested in the 950D since it was cheap and looked nice, plus it would mostly just be a backup for the TS100.  :)
I apologize for hijacking the thread. I hope the OP finds some of this useful.
« Last Edit: April 11, 2019, 12:58:47 pm by Mp3 »
Offline stj
« Reply #24 on: April 11, 2019, 05:10:53 pm »
that's bullshit,
i hotswap all the time with some longnose pliers.
