Author Topic: Reduce ringer volume on Commax DP-SS Intercom handset (ABSOLUTE beginner)  (Read 3881 times)
Offline Ellie DTopic starter
Hi there, no electronics knowledge at all I'm afraid, so please frame your answers as though addressing a small spotted terrier.... I'm keen but limited.  At work there's a Commax DP-SS intercom handset close to my head.  I'm hoping to significantly lower the ringtone using mechanical means, i.e glue foam to a speaker or something along those lines.  I opened the unit... very proud of that .... & found no discernible speaker at all.  Please see pics.  I don't have the knowledge to do anything fancy.  if handsets come with a volume adjuster  I could possibly wire that in instead.  I'd also be capable of throwing the current one out the window but that's not ideal.  In terms of compromise, I don't even need to be able to hear/speak to the front door guest.  A quiet ringtone would prompt me to walk to the door (without even speaking to the person).  Any dumbed down assistance much appreciated.  Thank you
(second image) Reduce ringer volume on intercom handset
« Reply #1 on: December 03, 2021, 11:32:52 pm »
Seems like initial post didn't accept both images so I'm attaching again here.  Thnx
Offline 妖怪女
Re: Reduce ringer volume on Commax DP-SS Intercom handset (ABSOLUTE beginner)
« Reply #2 on: December 05, 2021, 06:03:50 am »
That's weird. I looked at a picture of the model. What is on the other side of the base? (the cover) I see the speaker hole pattern in a picture. There is no speaker there?
If not, try taping the hang-up button down, and move the handset a few feet from the base and then have somebody ring the bell and see if the sound is actually coming from the handset.
Offline Rmen
  • Country: am
« Reply #3 on: February 21, 2024, 05:58:29 am »
Hello
Please make photo from back of PCB that show all wire track very clear and send.
I think sound generat out side of this device.
so after re engg shematic diagram it is possible better help.
Regards
Rmen
