Author Topic: How does this circuit work ? (Arduino auto power changeover circuit)  (Read 2508 times)
Offline whatsthegeekTopic starter
Hi, I've been trying to understand this circuit:
How does it block the USB 5v when the comparator detects there's more than 3.3v at the power jack ?
I think there's something I'm not getting xD
Hope someone can help ^^
Offline Nusa
Re: How does this circuit work ? (Arduino auto power changeover circuit)
« Reply #1 on: December 03, 2017, 03:00:59 pm »
It's actually detecting more than 6.6V at the power jack. Note the voltage divider reducing it by half before the comparator. The comparator controls the mosfet on the USBVCC line. It's a P-channel mosfet (arrow facing out, not in), so a high output from the comparator will turn it off.
Offline danadak
« Reply #2 on: December 03, 2017, 03:01:36 pm »
The comparator trips when the power jack reaches 6.6V, that
in turn turns off the PMOS fet that connects the 5V usbvcc buss
to the LP2985 regulator input.
Regards, Dana.
« Last Edit: December 03, 2017, 04:05:52 pm by danadak »
« Reply #3 on: December 03, 2017, 04:36:03 pm »
Oops, just noticed that xD
But there's something that I don't get, won't the current flow through the flyback diode of the mosfet ?
Offline glarsson
« Reply #4 on: December 03, 2017, 04:41:42 pm »
Only if the 5V from USB is above 5.6V.
Offline Nusa
« Reply #5 on: December 03, 2017, 04:58:33 pm »
What he said about diode voltage drop. It probably won't happen. Even if it does likely no harm done.
I believe the real purpose of the circuit is to keep the 5V voltage regulator from trying to power the USB line.
« Reply #6 on: December 03, 2017, 06:28:43 pm »
Ok, thanks for the explanation :)
I remade the schematic for my own device, is it correct ? would you change some of the components ?
Offline Peabody
« Reply #7 on: December 03, 2017, 07:01:41 pm »
That's not quite the same circuit as your first one.  Does Vin of the 3.3V regulator need to be tied to +5V instead of Vcc?
« Reply #8 on: December 03, 2017, 07:45:52 pm »
Yes, it needs to get power from the 5v rail otherwise, the board won't get 3.3v when powered from USB
Offline danadak
