Author Topic: best desolder setup below £130?  (Read 1161 times)
Offline cypher007Topic starter
« on: October 14, 2019, 09:11:51 pm »
looking for a desolder setup as when working on old 8 bit machines using a trigger solder pump is a pain.
was considering the ZD985. anything better at that sort of price or cheaper? ebay uk has the ZD985 but its from spain.
Offline MosherIV
Re: best desolder setup below £130?
« Reply #1 on: October 14, 2019, 09:47:01 pm »
Hi
Welcome to the forum.
Try this
https://cpc.farnell.com/duratool/d00672/desoldering-station-uk-eu-plug/dp/SD01384?scope=partnumberlookahead&ost=D00672&searchref=searchlookahead&exaMfpn=true&ddkey=https%3Aen-CPC%2FCPC_United_Kingdom%2Fw%2Fsearch
Looks like a Duratool clone of the ZD985
I have one of these
https://cpc.farnell.com/duratool/d01849/desoldering-iron-sucker/dp/SD01702
I have bought from CPC a number if times and can vouch they are ok to deal with, they are a subsidury of Farnell
« Last Edit: October 14, 2019, 09:53:51 pm by MosherIV »
The following users thanked this post: cypher007
Offline andy3055
Offline Gyro
« Reply #3 on: October 14, 2019, 09:57:09 pm »
Hi
Try this
I have one of these
CPC also do the spares, tips, filters, even the glass tubes really cheaply (way cheaper than any you can find on ebay)....
https://cpc.farnell.com/search?st=zd552&aka_re=1
Best Regards, Chris
« Reply #4 on: October 14, 2019, 11:30:30 pm »
I’ve got one of the yellow ones I bought from Maplin. Had variable results with it.
The duratool one I nearly bought but one guy on amazon who reviewed it said it was the worst one he’d used.
I don’t know maybe I’ll just have to get the zd985.
I saw another one by auyo I think it was. Has anyone had good or bad experience?
Offline MosherIV
« Reply #5 on: October 15, 2019, 07:02:15 am »
The yellow one works for me. I can desolder a 14pin dip chip.
I doubt you will find anything as cheap as the Duratool version of the zd985.
Bear in mind that there are only 2 bad review at 1star and similar for 2 stars, all the rest are positive.
It is a 'value for money' unit. However, I doubt you will get anything better buying unknown units from China.
I read one forum post from someone who rebuilt the gun from similar model with parts from Hakko.
One golden rule is to keep the trigger (vacummn) on for a couple of seconds as you take the tip away, it stops the solder from clogging in the barel.
« Reply #6 on: October 15, 2019, 11:33:59 am »
so the duratool is on a par with the zd985? if so ill just get that.
Offline Gyro
« Reply #7 on: October 15, 2019, 12:58:18 pm »
Yes, it is a 'brand name' import version.
You also have the benefit that CPC is a proper UK company, part of the Farnell group. So you have all the normal provisions, returns, warranty, safety assurances, etc. associated with buying from a reputable UK company.
P.S. The best way I've found to avoid clogging is to hold the PCB (near) vertical and the gun horizontal - it sounds odd but is surprisingly natural in practice, it also stops you putting excessive pressure on the solder pads.
One other thing, the ZD985 seems to have adopted a black plastic solder debris chamber, while the Duratool retains the original glass one (which afaik can also be retrofitted to the ZD985 and is only £2.45 from CPC).
« Last Edit: October 15, 2019, 03:27:56 pm by Gyro »
Best Regards, Chris
