I am anything but a troll, Electrical hypersensitivity is real, EMF stands for Electrical magnetic fields, and...thanks to some replies given, I will take the advice and go old school for a manual receiver with a turning knob. Arrivaderci
IF it interests some, here is ONE of many credible sites on the topic. It is a growing phenomenon.
https://pubmed.ncbi.nlm.nih.gov/32289567/
Almost any radio receiver manufactured in the last 80 years will have at least one internal oscillator.
Before that, there were Tuned Radio Frequency (TRF) radios which did not, but they were superseded by Superheterodynes, which were much easier to align accurately & having better selectivity, to use in the real world.
Googling will find so-called "TRF" radios based upon a single chip, which unfortunately, have many of the disadvantages of classic TRFs, but few of the advantages.
Prior to that, & for simple designs for many years later, there were Regenerative Receivers, which used positive feedback to cancel circuit losses.
They could also be operated in Oscillating mode, which made it easier to receive Morse & SSB signals, so such a radio would also be a "no-no".
Then there are "crystal" sets which don't use any active devices.
They are not very sensitive however, & work best when you are relatively close to the transmitting station.
In that case, any RF energy from your receiver is the least of your problems.
In any case, the device you are using to post on this forum has oscillators in both the unit itself & the switch mode power supply, either internal, or part of its charger.
There are also natural sources of Electromagnetic fields----a relatively close (several km away) lightning strike generates a much higher field strength than anything in your home.
