Author Topic: best practices in detecting relay contacts status  (Read 1013 times)
Offline Sultanpepper123Topic starter
  • Country: eg
« on: October 22, 2019, 07:23:52 pm »
Currently i'm experimenting with 12VDC energy meters latching relays and at least for me the feature of detecting status of contacts ( required by some clients ) which is built in as in the diagram below is quite interesting. Now i need to interface it to a microcontroller safely. At the top of my head i may think of using an optocoupler but my understanding is i need to isolate the grounds ? thus making the design a bit pain in the kneck, is this the only feasible method or are there other approaches ?. enter image description here
TL;DR pins 4 and 5 switch on / off depeding on status of relay, how do i sense/ measure status of the latch with those pins?
Offline GerryR
Re: best practices in detecting relay contacts status
« Reply #1 on: October 22, 2019, 08:50:34 pm »
If the 4,5 contacts are isolated, why not tie one contact to a pull-up resistor and feed the other to a micro input.  If the micro inputs are already pulled up, then tie one contact to the micro common and the other to the micro input of you choice.  The change of state tells what position the relay is in.  :-//
Still learning; good judgment comes from experience, which comes from bad judgment!!
The following users thanked this post: Sultanpepper123
  • Country: eg
« Reply #2 on: October 22, 2019, 09:01:46 pm »
Thanks for the suggestion, looks simple enough. What made me worry at first whether there was any EMI or transients i should worry about.
Offline mikerj
« Reply #3 on: October 22, 2019, 09:20:53 pm »
Not from the isolated contacts themselves.  Avoid routing the connections between the contacts and the microcontroller close to, and parallel with the switched side of the relay coil.
  • Country: eg
« Reply #4 on: October 22, 2019, 09:38:00 pm »
Really appreciate the help and sharing your thoughts.  :-+
Again thank you sir for the help .  :-+
