Author Topic: Ceramic capacitors with Z as tolerance. What does it means?  (Read 7012 times)
Offline sean87Topic starter
  • EE WannaBee
    • EMBEDONIX
Hi all,
In one of my expiriment boards a ceramic capacitor with written value of "104Z" is broken and I have to replace it. I think this is a 0.1µF Cap, but I am not sure what is that Z is standing for. On the net it is written +80% and -20% tolerance also it says these capacitors are Assymetric?? Can somone explain this please and can I replace this with a 104K cap?
Thanks.
EMBEDONIX - Embedded Systems, Linux and good stuff!
Offline Zero999
  • 0999
Re: Ceramic capacitors with Z as tolerance. What does it means?
« Reply #1 on: July 11, 2011, 05:32:22 pm »
Tolerance is the acceptable range of values the component can have, in order for it to pass QA.
K is 10% so is a suitable replacement for +80% -20%
  • EE WannaBee
    • EMBEDONIX
« Reply #2 on: July 11, 2011, 07:08:37 pm »
So Z means it can be +80% more or -20% less than actual value?
Online ejeffrey
« Reply #3 on: July 11, 2011, 07:22:55 pm »
Yes.  That is a common tolerance rating on capacitors intended for power supply filtering, including a lot of aluminum electrolytics.  The tolerance doesn't matter much, and especially extra capacitance almost never hurts.
