Author Topic: Why is impedance mentioned in DC circuits?  (Read 2175 times)
Offline MrBondTopic starter
« on: January 10, 2022, 01:21:21 pm »
Hi, whenever i watch Dave and many other guys on youtube the word impedance is thrown around every time even if the circuit being discussed is purely DC, no AC to speak of. But yet again and again impedance is mentioned. Now if you know the formula for calculating impedance you need a frequency, which DC does not have. It's just confusing.
The following users thanked this post: Electro Fan
Offline Grandchuck
Re: Why is impedance mentioned in DC circuits?
« Reply #1 on: January 10, 2022, 01:39:54 pm »
With no reactance, Z = R
The following users thanked this post: Electro Fan, tooki
Offline Terry Bites
« Reply #2 on: January 10, 2022, 02:33:53 pm »
Impedance can be resistive or reactive. Its a catch all term for any component or network that impedes the flow and/ or direction of a current. For example a dc current will increase in an indcutor until at some point in time it reaches a maximum value. "Time" being the operative word. DC circuits are not necessarily scalar but may also contain vector quantities.
The DC operating point in any circuit cannot be achieved intantaneously. V=IR after a bit!
The following users thanked this post: Electro Fan, FileNotFound__
Offline M0HZH
    • QRPblog
« Reply #3 on: January 10, 2022, 03:28:37 pm »
Even in a DC circuit, the reactive part of the impedance matters when you're looking at transients or ripple/noise.
The following users thanked this post: amyk, Electro Fan
« Reply #4 on: January 10, 2022, 03:47:28 pm »
Well ok, but why use the term in the wrong way thus making it more confusing for people that just began learning about this stuff, such as myself?
« Reply #5 on: January 10, 2022, 03:50:22 pm »
So let me get this straight, you're supposed to treat ripple as a frequency that introduces the idea of impedance into the circuit.
Offline voltsandjolts
« Reply #6 on: January 10, 2022, 03:55:57 pm »
Impedance (resistance and reactance) are always there, to some extent.
Perhaps the reactance is so small you can't measure it with the equipment you have, but its there nonetheless.
In every wire, pcb trace, connector and component....
Offline Grandchuck
« Reply #7 on: January 10, 2022, 04:08:19 pm »
Not the wrong way.  I can see how it is confusing.  It is just that impedance, Z, is always appropriate to use when discussing the opposition to the flow of current.  All practical circuits have impedance (except superconducting ones ... not often relevant).  Some circuits have reactance that can be ignored (often called purely resistive ones).  In those, resistance, R, is appropriately used.
Offline M0HZH
    • QRPblog
« Reply #8 on: January 11, 2022, 10:45:19 am »
Yes, ripple is in fact an AC signal superimposed on your DC signal; when you are looking to remove ripple you're supposed to analyze the circuit in terms of impedance. The same goes for transients like switching the circuit on or off, adding/removing a load or any significant change in voltage or current. That's why you have filtering capacitors for example, they present a high resistance but a low impedance for noise/ripple/transients etc.
Offline BeBuLamar
« Reply #9 on: January 11, 2022, 12:28:37 pm »
If a circuit that has a diode in series with a resistor, would we call that impedance or just resistance? The current flow into the circuit is certainly not proportional to the voltage.
Online Bud
« Reply #10 on: January 11, 2022, 02:12:25 pm »
It is called dynamic resistance or non-linear resistance.
Offline Terry Bites
« Reply #11 on: January 11, 2022, 02:22:19 pm »
A network
Offline Benta
« Reply #12 on: January 11, 2022, 10:19:19 pm »
No one is using this in the wrong way.
It's a semantics question:
Impedance and Admittance are the top-level terms, so if you use those, you'll never be wrong. The attached table should help (Impedance = 1 / Admittance and vice versa):
« Last Edit: January 11, 2022, 10:22:37 pm by Benta »
Offline radiolistener
  • Country: ua
« Reply #13 on: January 12, 2022, 01:06:32 am »
There is no confusing. If you use DC, you can put 0 Hz in the formula, because DC is actually AC with a frequency 0 Hz.
Impedance is important, because it allows to understand how much current can flow through circuit. If impedance has reactance, you can understand circuit behavior for a transient process.
« Last Edit: January 12, 2022, 01:10:22 am by radiolistener »
Offline brabus
« Reply #14 on: January 12, 2022, 03:59:37 pm »
Some say there is no such thing as DC.
What you see as a DC voltage or current is the result of a stable dynamic system, obtained through a proper balance of impedance modules, transfer blocks and feedback phenomena, even in the simplest circuits with no apparent reactive component.
Furthermore, one can say "high impedance" or "low impedance" when the reactive component is simply unknown. Take for example an opamp: the input stage is often JFET, thus presenting very high resistance and very low capacitance. Short said: a very high impedance.
« Reply #15 on: January 12, 2022, 04:09:43 pm »
It's not "the wrong way", 'impedance' is just a broader term that includes 'resistance' and 'reactance' in the same way that 'number' is a broader term for 'integer',  'fraction' or 'real'.
Offline KT88
« Reply #16 on: January 13, 2022, 10:45:46 am »
Resistance alone doesn't exist in the real world. It can be used to simplify the circuit analysis if one is interested in the steady state behaviour of a DC signal - but this is always a simplification of actual real-world circuits.
Mentioning impedance most of the time reminds us not to forget about this fact.
The following users thanked this post: brabus, Electro Fan
