Hi guys,
I have developed a watchdog device that can power cycle a device by cutting of power via a low side n mosfet switch. As I want to make this a bit more professional, I wanted to pick your brains. Some people I talked to considered the low side switch a bad idea because you dont know what happens inside an embedded device if you take away ground.
How do I do this "better"?
As the attached device is not always the same one, I can only work from the spec of 5-19V up to 1.5A.
Thanks!
