Author Topic: new scope, need probes  (Read 2587 times)
Offline FlumpTopic starter
« on: October 19, 2013, 02:46:14 pm »
Hi all
Just purchased my first scope off ebay, its a cheap low spec one
and doesnt come with probes, i am not going to be doing anything
important with it, its just for experimenting and playing with at
beginners level, going to use it for developing mic preamps and
basic stuff like that.
is it worth the extra for me to get decent probes or is it okay for
to get a pair of cheap probes for the stuff i plan on doing with it ?
Offline Caca
  • Country: cz
Re: new scope, need probes
« Reply #1 on: October 19, 2013, 03:18:22 pm »
Hi, I think taht even the cheapest probes should be fine if you don't want any high frequencies
Offline G7PSK
  • It is hot until proved not.
« Reply #2 on: October 19, 2013, 03:26:07 pm »
Those cheap probes work very well for anything under 50MHZ and can be had from Ebay very cheaply I get the sets of four for under £20.00 including shipping, they are cheap enough not to worry about damaging the tips etc. I also fixed a set to 10 X and fitted identification pins so that they would switch my scope to the correct reading I have another pair set to 1X with pins on them as well I just put some supewr glue on the switches so mistakes are not made.
Offline npnlamp
« Reply #3 on: October 19, 2013, 03:30:42 pm »
Get cheap ones, I dont think you need high frequency ones. Cheap set of probes on ebay:
http://www.ebay.com/itm/40MHz-Oscilloscope-Scope-Crocodile-Alligator-Clip-BNC-Connector-Probes-Max-600V-/180738642983?pt=LH_DefaultDomain_0&hash=item2a14dcd427
What scope do you have? What frequency it is?
« Reply #4 on: October 19, 2013, 04:48:19 pm »
thanks very much guys, I will get a cheap set then.
here is the scope I got incase anyone is interested
http://www.ebay.co.uk/itm/111187493856?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I think I will get these probes
http://www.ebay.co.uk/itm/370890121183?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Offline G7PSK
« Reply #5 on: October 20, 2013, 09:37:00 am »
You wont go wrong with those. :-+ :-+
Offline KJDS
    • my website holding page
« Reply #6 on: October 20, 2013, 11:30:34 am »
I've got four of those probes, they are good value.
