Hi good day everyone.
Sorry if this topic had been beaten to death.
I followed a simple zener diode testing circuit from this youtube video
https://youtu.be/of86B18H4c8For context, I'm using a 19V DC power adapter from an old laptop I had lying around so all calculations were made based on my supply voltage.
For testing I tested on a spare 12V BZX55C zener I had lying around.
The datasheet indicates a V
nom of 12V and I
F 200mA
From the equation
(Vin-Vout)/R = 1
I got
(19v-12v)/R=200mA
7/R=200mA
7v/0.2V = 35 ohm
I soldered multiple resistors for a measured value of 40 ohm.
However when put in the test jig the measurement rose up to roughly 10V (am I supposed to get a ballpark of ~11V based on 40 ohm?)
It got hot and melted the solder joint between diode and resistors.
Was my power adapter delivering too much current? Should I have used a pair of 9V battery (and adjust calculations accordingly) instead?
