Author Topic: Unknown Through Hole Solder Joint  (Read 1220 times)
Offline GM_SchwartzTopic starter
« on: March 23, 2018, 02:33:01 am »
Hello all,
I have been desoldering some components from an old CRT TV recently, and I ran into a type of solder joint I've never seen before. You will notice a "flower pedal" pattern on the joint. This was revealed after removing most of the solder from the joint. I have been unable to find a reference to this type of connection online.
The following is total speculation.
I think this could be some sort of riveted connection that was added for support or to prevent easy removal of the component. What I'm imagining is something similar to the "copper rivet" image I attached, except that it's small enough to fit inside the component hole, and is slotted at the bottom. The manufacturer would flatten out the rivet on the bottom side of the circuit board during construction of the board. This could explain the "flower pedal" pattern observed on the "unknown solder joint" image.
I have attached images of the type of joint from above and below. Also, I have included an image of a copper rivet, which I am imagining being inserted in the component hole.
Thanks in advance to anyone who corrects me or has any more information on this.
Offline drussell
  • Hardcore Geek
Re: Unknown Through Hole Solder Joint
« Reply #1 on: March 23, 2018, 02:47:07 am »
Yes, it is relatively common to find those various styles of "riveted" tie-points for additional physical structure.
Offline TheDane
« Reply #2 on: March 23, 2018, 08:08:59 am »
It seems close to a high power circuit, so it might also be used to prevent PCB damage/fire.
If/when a solder joint goes bad, the resistence will go up. This will heat up the board, eventually burning it - making the fiberglass conductive carbon = bad situation.
Offline TassiloH
« Reply #3 on: March 23, 2018, 09:27:38 am »
I would guess that is a method to protect the solder joint from mechanical stress on single sided boards. On a single sided board, a regular solder joint will take pulling on the component leads pretty well, but a pushing force will act on the glue between copper and board. That glue bond is not very strong, especially on the FR2 board you are showing. So for power semiconductors (thermal cycling/expansion) or switches/pots the rivets make sense.
« Reply #4 on: March 23, 2018, 08:18:02 pm »
Thanks to all for the responses. Time to work on removing them now... =)
