Author Topic: Beware when buying DMMs on ebay, fuses ain't cheap!  (Read 20160 times)
Offline cthreeTopic starter
« on: June 04, 2013, 07:29:46 pm »
So I thought I scored a great deal on a Fluke 87III DMM on eBay for $100. $20 in shipping and I was set.
However...both fuses are blown! Doh! That's $100 from Digikey to replace those bringing the total closer to $220, more than double the purchase cost.
If you are buying a used multimeter, like a Fluke 87 or similar, make sure you ask to see it measuring current (on both channels in the case of a Fluke 87 et al).
It can really add up to replace those. $45 for the 11A fuse, $36 for the 440mA fuse. $8 in shipping plus tax and ouch!
This is probably just a rookie mistake on my part. Oh well.
Offline Lightages
  • Canadian po
Re: Beware when buying DMMs on ebay, fuses ain't cheap!
« Reply #1 on: June 04, 2013, 07:45:33 pm »
For those wanting HRC fuses and don't want to spend more than the meter:
http://www.testequipmentdepot.com/amprobe/accessories/fuses.htm
FP410    Amprobe FP410 11A/1000V Fuse    1000V    11A    pack of 2    $15.15
FP412    Amprobe FP412 FA.44A/1000A/10001A    1000V 44A   pack of   2    $16.10
or
http://www.testequipmentdepot.com/uei/accessories/fuses.htm
AF38 440mA, 1000V Fuse  qty:1   Sale  $7.95
AF39    DM391
DM393    11A, 1000V Fuse  qty:1   Sale $7.95
Plus shipping of course.
If you are buying a new multimeter, it is always best to buy at least one spare set of fuses at the same time.
Offline dfmischler
« Reply #2 on: June 04, 2013, 07:51:24 pm »
Those fuses can be found on ebay for a lot less.  One Source of Fuses
When I bought a supposedly fully tested Fluke 87-V that turned out to have a blown 44/100 A fuse I asked the seller for a partial refund and referenced another ebay seller who had them.  He refunded enough of my money to buy the fuse.
Offline Lightages
  • Canadian po
« Reply #3 on: June 04, 2013, 08:04:40 pm »
That is a great deal! A great deal if you live in the US :(  They won't ship outside of the US.....
Offline AndyC_772
« Reply #4 on: June 04, 2013, 08:09:12 pm »
I found prices vary wildly for these DMM fuses, apparently for the same thing - it pays to look around. For example, compare:
http://uk.rs-online.com/web/p/multimeter-fuses/2010251/
http://uk.rs-online.com/web/p/cartridge-fuses/4597918/
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #5 on: June 04, 2013, 08:35:07 pm »
That's very expensive; new fuses at worst at $20 each delivered in the USA.  Typically you can get them for about half that.  If the fuses are blown you'd also best check the DMM carefully, to insure it wasn't damaged by the previous owner.
The fuses are made by Bussman specifically for DMM, and via reputable dealers in the USA, range from $5-8 each.
http://www.amazon.com/DMM-11A-Fluke-Digital-multimeter-replacement/dp/B007QU1TQQ/ref=pd_cp_hi_0
Be careful about buying fuses on eBay, a good number are counterfeit, as there is no way to check a fuse for authenticity except by careful comparison of its construction, or destructive testing.  So, spend the extra few dollars and get it from an authorized distributor for Fluke.
Best Wishes,
 Saturation
Offline retiredcaps
« Reply #6 on: June 05, 2013, 04:00:16 am »
Are you sure the prices on digikey that you are seeing aren't for quanity = 5?
http://www.digikey.com/product-search/en/circuit-protection/electrical-specialty-fuses/656626?k=fluke%20fuse
The ones that are $45 I see are for quantity = 5.
« Reply #7 on: June 05, 2013, 05:43:25 am »
Shipping from USA to Canada is usually brutal. Digikey charges $8 for overnight, $0 if you spend over $200.
These are the two fuses I found for the Fluke 87:
http://www.digikey.ca/scripts/dksearch/dksus.dll?vendor=0&keywords=F5081-ND  $37  qty 1
http://www.digikey.ca/scripts/dksearch/dksus.dll?vendor=0&keywords=F5082-ND  $45  qty 1
The BUSSMANN fuses are a little less but non-stocked and qty 10 min.
retiredcaps has the correct links. Why they are 8x the price when you look in the wrong category for the same parts kinda pisses me off. There is a big difference between 8+6 and 45+37 for the exact same parts,
Stupid. I'll definitely get the Fluke branded ones for 1/8th the price of the OEM branded ones. Thanks for the find, I totally missed it.
« Last Edit: June 05, 2013, 05:52:51 am by cthree »
Offline David_AVD
« Reply #8 on: June 05, 2013, 05:48:04 am »
Those $40 Digikey items say "Standard Package   10" so maybe that's 10 fuses?  It does look confusing.
Offline retiredcaps
Offline retiredcaps
« Reply #11 on: June 05, 2013, 05:56:01 am »
If you don't mind sharing the actual auction, let's see the seller description.
If it is listed as "works perfectly", then I would complain about the blown fuses and ask the seller to refund $20 to help pay for new fuses.
If there is no disclaimer regarding the fuses or "as is" clause, then chances are the seller listed the item as used.  If yes, used on ebay means
"An item that has been used previously. The item may have some signs of cosmetic wear, but is fully operational and functions as intended."
Note the words "fully operational".
Offline mikes
« Reply #12 on: June 05, 2013, 01:59:42 pm »
pack of 5, fluke branded, $23 at mouser. Or you can  buy 1 for $9.
« Reply #13 on: June 05, 2013, 02:18:27 pm »
http://www.ebay.ca/itm/111056150139
Not sure if you see it but at the bottom I specifically asked if it was tested and was told it was tested and fully working.
Thanks for your advice. I will contact the seller and ask for a partial refund to cover the cost of the fuses.
Offline saturation
    • NIST
« Reply #14 on: June 05, 2013, 03:24:38 pm »
Be cautious about buying boxes of these fuses, if you are a professional electrician, yes, it pays.  But if you are a design engineer or a hobbyist, the likelihood you'll blow a fuse is fairly slim.  Electricians probe many unknowns, usually at line voltage, and the chances of them missetting their DMMs from repeatedly doing the same work is high, thus the blown fuse.  But design work puts the mind in gear 100% of the time, so repeatitive mindless tasks are fairly minimal.  Otherwise, you'll have a box of spare fuses you'll never use, but you could sell your excess for $10 each on eBay  :-DMM.
Best Wishes,
 Saturation
jucole
  • Guest
« Reply #15 on: June 05, 2013, 03:26:26 pm »
I personally don't think you have a right to expect a "used" item to be fully operational;
but because you asked the question..
Q: Does this meter work? You don't show any pictures showing the LCD on. Did you test it?
A: The meter has been tested and works just like it should. Thanks!
Means to me that something as major as expensive blown fuses is nothing short of dishonesty on his part.    You should definitely ask for all your money back or him to re-inburse you for the money for the fuses.   But if you don't get a reply within a few days, just raise an Ebay dispute.
« Last Edit: June 05, 2013, 03:28:19 pm by jucole »
Offline krivx
  • Country: ie
« Reply #16 on: June 05, 2013, 04:26:02 pm »
I've always wondered, does a blown fuse mean a re-cal is needed for current ranges?
Offline Balaur
« Reply #17 on: June 05, 2013, 04:27:54 pm »
Should not, voltage is sensed only on the resistor shunt.
Offline houdini
« Reply #18 on: June 05, 2013, 04:36:52 pm »
And you guys are surprised when these things get replaced with a 15Cent bolt.
Offline Lightages
  • Canadian po
« Reply #19 on: June 05, 2013, 04:42:36 pm »
I am never surprised with human stupidity, just a bit discouraged. Fuses aren't that expensive as has been pointed out. It just needs a bit of research and thinking......
Offline retiredcaps
« Reply #20 on: June 05, 2013, 05:24:16 pm »
I think you have a valid complaint.  However, the only problem is that you already left feedback saying no problems.
The seller could dispute and ebay/paypal is likely to side with seller based on your feedback.
You could point out this thread to the seller as proof that your fuses are blown and you are not lying about it?
Let us know the outcome.
Offline retiredcaps
« Reply #21 on: June 05, 2013, 05:31:12 pm »
Why not?  That is ebay's category rating and their definition.
If item is not fully operational, it should be listed for parts or broken then.
« Reply #22 on: June 05, 2013, 08:17:53 pm »
Very! Standard package is the package size for Digikey, not the customer. If you buy 2, you get 2, not 20. I just received three 11A fuses and 2 440mA that I ordered. I can confirm that I received 3 and 2 respectively, not 30 and 20. These have to go back in exchange for the orders of magnitude cheaper Fluke part numbered ones.
The seller is going to refund me the price of the fuses.
Offline Fsck
  • sleep deprived
« Reply #23 on: June 05, 2013, 08:26:34 pm »
Newark should have fuses for 7-8$ a pop in 5-packs.
"This is a one line proof...if we start sufficiently far to the left."
Offline retiredcaps
« Reply #24 on: June 05, 2013, 09:47:45 pm »
Good for seller vetteharley1 for doing the right thing.  :-+
Offline David_AVD
« Reply #25 on: June 05, 2013, 10:39:29 pm »
The only fuse I recall ever blowing on a DMM was the 200mA range.  With brain engaged, it's hopefully not a frequent event!   :D
Offline Lightages
  • Canadian po
« Reply #26 on: June 05, 2013, 10:50:56 pm »
I have never personally blown a fuse in any multimeter I have used since I started electronics and electrical work, back in the 70s. Is it because I am exceptionally smart and diligent?  :-DD NO! It is because I developed a habit, a mental checklist so to speak. Every time I am finished with a multimeter I ritually put the range into the highest DC voltage range and unplug and replug the leads into the common and volt inputs. This ritual has saved me from harm. Is it foolproof? No but it is very helpful. I learned to do this after the first time I left my analog multimeter in some low range on current and then attempted to measure a wall socket without checking.
I am glad the seller made good, and I am glad you can now see that the fuses don't need to be expensive. If you are buying one, you should buy a backup too! It is a good idea to have spares on hand. Actually I think every respectable meter manufacturer should be supplying a spare set of fuses with every meter they sell.
« Last Edit: June 05, 2013, 11:07:22 pm by Lightages »
Offline David_AVD
« Reply #27 on: June 05, 2013, 10:54:01 pm »
This is something I've always done too and bares repeating.  It's one of those fundamental rules for using test gear.   :-+
« Reply #28 on: June 06, 2013, 03:12:45 am »
I'm not working with anything near 11A, more like sub-100mA, 200mA max. I always use the A post to measure current unless in check it first on A before moving to mA.
I have 3 fluke 87 meters, one 87V and 2 87III's. they take the same fuses. Oddly my 87V which I also bought on eBay has a blown 11A fuse as well. I never noticed probably because I haven't used it to measure current before.
I am ordering 3x11A and 2x440mA fuses to fix the 3 blown ones and have a spare set on hand.
If you go on digikey and search for an 11A, 1000V fuse you get, the $45 one and a BUSSMAN one for $39 with is the one fluke uses as original equipment but which is sown out of stock and a minimum qty of ten, so $390 for 10 minimum.
If you search for 'fluke fuse' you get the above BUSSMAN, exact same part, but from Fluke, in stock, qty 1 for like $8. You only get the cheaper price if your search includes the word fluke.
Offline nukie
« Reply #29 on: June 06, 2013, 06:35:30 am »
In China, there are no fuse to blow and there's handheld multimeter with DC power input.
« Last Edit: June 06, 2013, 06:37:23 am by nukie »
Offline saturation
    • NIST
« Reply #30 on: June 06, 2013, 11:55:11 am »
Amazing ... and from the look of the DMMs they are heavily used.  As mentioned earlier if you pay attention you may never blow a fuse but human nature ... :-BROKE
http://serenityinchina.wordpress.com/2011/05/17/china-street-scenes-doing-electrical-wiring-above-streetin-middle-of-street/
In China, there are no fuse to blow and there's handheld multimeter with DC power input...
Best Wishes,
 Saturation
« Reply #31 on: June 06, 2013, 10:07:21 pm »
The saga continues... |O
The cheaper, $8 and $6 fuses are only available from digikey.com, not digikey.ca. If you search for "fluke fuses" on digikey.ca you get nothing. I guess they aren't authorized to sell Fluke products in Canada. When I try to add the Fluke fuse to my cart I get:
"Due to vendor restrictions, we are unable to add this item to your order."
Perfect! grrr
« Reply #32 on: June 07, 2013, 01:54:55 pm »
Newark has them in Canada for $9 and $6 each.
While this episode has been a real pain in the ass I have to say that digi-key is pure awesomeness. Yes it's going to cost me money to send these fuses back but they aren't dicking me around, they even sent me a fedex return shipment label and are charging just $8. That's less than parcel post at the post office.
<3 Digi-key
Offline tooki
« Reply #33 on: March 12, 2015, 01:48:48 am »
Any idea of how to tell whether a fuse is genuine, besides destroying it? I (stupidly, in hindsight  :palm: ) ordered some off ebay (granted, the seller has a high rating) because here in Switzerland, anything that electrons flow through that isn't a PC component costs a go•••••ed fortune. The ebay seller with free shipping was much cheaper.
One of them appears to have a pad-printed label, the other appears to be inkjet. Had I seen that a few years ago it would have been a dead giveaway, but with industrial inkjets being widely used for legitimate applications these days, I can't be sure.
"How bad could they be?" I asked myself, but this was before watching Dave and others tear apart cheap Chinese crap and seeing exactly how horrific it can be!
Mind you, I only got them as spares to keep on hand, the Fluke 87V still has its factory fuses in it, and I don't actually plan on blowing them. I assume that if I did blow a fuse somehow, these potential fakes could still tide me over for low-voltage stuff till I procured a definitely-real fuse.
Any thoughts? Thanks!
« Last Edit: March 12, 2015, 01:51:50 am by tooki »
Offline retiredcaps
« Reply #34 on: March 12, 2015, 04:18:34 am »
A picture or link to your auction might help us help you.
Offline tooki
« Reply #35 on: March 13, 2015, 03:13:17 pm »
Sure, thank you!
The auction (well, buy it now) is here: http://www.ebay.com/itm/231265056155?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Here are the products received. Note that the copper-looking reflections on some of the pictures are not bare copper, it's just my hands reflected onto the silver end caps with lots of flash illumination. Click any image to see the full 16MP (~4MB) image.
« Last Edit: August 05, 2015, 03:48:23 pm by tooki »
Offline Zbig
« Reply #36 on: March 13, 2015, 08:27:20 pm »
[..] because here in Switzerland, anything that electrons flow through that isn't a PC component costs a go•••••ed fortune.
And comes see what I did here? in the shops like this one ::) :
Offline retiredcaps
« Reply #37 on: March 13, 2015, 10:44:50 pm »
I have seen the seller, instrument_queen, on ebay before when he/she first starting selling T&M equipment/accessories.  My guess is that he/she is selling legit Fluke multimeters and mostly legit Fluke accessories.  Some of the carrying cases are obvious knockoffs designed to look like Fluke.
As for the fuses, I believe them to be genuine because Bussmann changed their look sometime in 2014.  The pictures you provided seem consistent with the new branding.  See
http://www.cooperindustries.com/content/public/en/bussmann/electrical/resources/product_information/fuses-made-simple-control-circuits.html
Having said that, Bussmann does have a document warning users to be careful of counterfeit fuses (which I can't find right now).
Online Zero999
  • 0999
« Reply #38 on: March 13, 2015, 11:03:32 pm »
The purple one appears to be fake. It looks like the label was printed on an ink jet and there's a spelling mistake "Asserbled in Mexico" The r could be an n but there's no way it's an m because there isn't enough space between the letters.
http://www.tooki.net/photos/dmmfuses/hires/DSC_4098.JPG
Offline EEVblog
« Reply #39 on: March 14, 2015, 01:57:07 am »
Yeah, you've really got to worry about the Chinese ones on ebay. Would be interest to dissect a genuine one and a known fake one (the spelling mistake is a dead give-away)
Offline cosmicray
« Reply #40 on: March 14, 2015, 03:11:29 am »
The red one says 10kA, while the purple one is 20kA. That's quite an improvement.  :o
it's only funny until someone gets hurt, then it's hilarious - R. Rabbit
Offline Wytnucls
« Reply #41 on: March 14, 2015, 04:14:06 am »
The UL certification mark is also wrong.
The reversed letter should be rounded at bottom right:
Offline Fat
« Reply #42 on: March 14, 2015, 04:53:16 am »
The above SKUs are for quantity = 10.  There are 10 fuses for each 1 package.
Apparently whoever is packaging these thinks if you blow one fuse you'll continue to blow fuses, hence the package of 10.
Offline dannyf
« Reply #43 on: March 14, 2015, 10:24:00 am »
They must be one of those rumored super-duper fuses that can also do your laundry and clean your house, :)
Offline tooki
« Reply #44 on: March 14, 2015, 11:53:54 am »
Does the consensus seem that the red one is real and the purple one is fake?
Dave, you want me to mail you the fake one for dissection? I don't know enough about these for it to be worthwhile for me to dissect it myself. (Have you gotten mail from Switzerland before?? :P)
Offline tooki
« Reply #45 on: March 14, 2015, 12:10:03 pm »
Hahahahahah! That's in Basel, so I hadn't seen it! (I live in Zurich.) But honestly, they should move that shop to Wankdorf.
Offline retiredcaps
« Reply #46 on: March 14, 2015, 10:10:03 pm »
Good eye. I didn't see that at first pass.  :palm:
Offline retiredcaps
« Reply #47 on: March 14, 2015, 10:11:16 pm »
Bussmann datasheet says 20kA is correct for the DMM-B-11A.
http://www.farnell.com/datasheets/287359.pdf
Offline cosmicray
« Reply #48 on: March 15, 2015, 12:58:23 pm »
The datasheet also says that the DMM-B-11A is slightly longer than the 10K version. Look carefully at the image where the 2 are shown horizontal next to one another. The purple (DMM-B-11A) is slightly longer. Perhaps these are 2 different fuse types.
Offline neslekkim
  • Country: no
« Reply #49 on: March 15, 2015, 02:11:15 pm »
Checking the same ones at Farnell, it seems its sold in qty of 1 for this price..
Offline tooki
« Reply #50 on: March 15, 2015, 02:15:47 pm »
The pictures clearly show they're two different fuses. The red one is the 440mA, the purple the 11A. (Intended for a Fluke 87V.) The seller sold them as a set.
Online Zero999
  • 0999
« Reply #51 on: March 15, 2015, 09:43:56 pm »
The purple one is certainly fake.
It's possible the red one is real but the fact it was sold to you with a fake puts that in doubt.
You should return them to the seller and ask for a refund. If they refuse go to ebay and use this thread as evidence.
Offline kamcm
« Reply #52 on: June 17, 2015, 07:32:40 pm »
Anyone know if the 'REAL' fuses have a difference in weight (0.5g) (5.89g vs 6.37g)? :-//
I purchased all of them from a seller located in China. :'(
please advise,
Thanks
« Last Edit: June 17, 2015, 07:41:13 pm by kamcm »
Offline ivan747
« Reply #53 on: June 17, 2015, 07:34:44 pm »
or
AF39    DM391
Just like car replacement parts.
Offline ivan747
« Reply #54 on: June 17, 2015, 07:36:14 pm »
Anyone know if the 'REAL' fuses have a difference in weight (0.5g)? :-//
please advise,
Thanks
Open one up, see if they're filled with sand or not.
And next time, don't buy fuses from China.
Online wraper
  • Country: lv
« Reply #55 on: June 17, 2015, 07:54:23 pm »
please advise,
Thanks
They look fake. Genuine ones look like this:
Online wraper
  • Country: lv
« Reply #56 on: June 17, 2015, 07:56:53 pm »
Except completely different marking, metal caps are crimped not like on genuine fuses and look awful.
Offline kamcm
« Reply #57 on: June 17, 2015, 10:04:05 pm »
please advise,
Thanks
Thanks for the info
Offline codeboy2k
« Reply #58 on: June 17, 2015, 11:08:23 pm »
About once every 2 years I slip up and blow a fuse, so I only keep one spare handy for when I need it.
Last time I bought 2 from Testpath:
https://www.testpath.com/Items/Fuse-11A-1000V-10-x-38mm-Fast-Acting-116-230.htm $9.95
they accept all credit cards for US and Canada buyers,  but international orders have to pay by wire or money order. They ship to Canada for just $7.95 (same as the US) and there are no additional handling fees, whereas international orders have $10.00 tacked on. They almost treat Canada like the 51st State :)  Good to see vendors realizing that it's easy to do business with Canadian buyers.
You can get 2 from Aliexpress for about $11. These actually look legit, but who knows. I would hate to bet my life on it if I was an electrician, but it's probably OK for my bench uses.  I'd like to crack one open, but then you can't use it and your cost goes up, so it's better to just buy from a known dealer anyways.
http://www.aliexpress.com/item/2-pcs-DMM-B-11A-Buss-Fuse-Amp-for-Fluke-Digital-Multimeter-Bussmann-1000V/1756310371.html
