Author Topic: Binding posts 60V 60A high quallity - help.  (Read 2160 times)
Offline FriedMuleTopic starter
  • Can make even the simplest task look imposible.
« on: May 01, 2019, 04:47:34 pm »
I have searched the net for binding posts that can take banana, bare cable and spade/fork connectors but I can't seem to find much above 36A and if, it looks like some cheap terminals that would never handle 60A or everyday usage.
Is there any brand, place or whatever to look fore, to get really quality?
Even if I appear online is it not necessary so, my computer is on 24/7 even if I am not on.
Offline LateLesley
  • Country: scotland
Re: Binding posts 60V 60A high quallity - help.
« Reply #1 on: May 01, 2019, 04:51:01 pm »
« Reply #2 on: May 01, 2019, 11:33:57 pm »
I found these with a quick google, if they are any good ??
https://cpc.farnell.com/cliff-electronic-components/cl159825ra/binding-post-60a-red-screw/dp/CN19538
Yes I saw them too but was not sure if they are okay, they do not look like the usual on the front. Not that it is bad, was just not sure.
Offline Electro Detective
« Reply #3 on: May 01, 2019, 11:41:35 pm »
Perhaps a look at automotive car hi-fi accessories may be a go.
I've seen some way out heavy duty binding post combos (banana, bare cable and spade/fork connectors)
with lots of metal to cope with mega amps
Maybe butcher a cheap or dumpster non working car amp for the jumbo connectors?  :-//
Good luck mate  :-+
The following users thanked this post: LateLesley
Offline tooki
Offline tooki
« Reply #5 on: May 02, 2019, 01:00:30 am »
Here you go: https://www.sks-kontakt.de/en/test-measurement/products/sockets
The PKN models are rated to 63A. Hirschmann is top quality.
Offline radiolistener
« Reply #6 on: May 02, 2019, 01:32:02 am »
60A 60V is 3.6 kW power, it's the same as two home oil heaters powered together at max power.
So, you can use power plug from oil heaters :)
Offline Jwillis
« Reply #7 on: May 02, 2019, 07:15:40 am »
Why would you need to go higher than 30 A .Even really good quality 4mm banana plugs are only rated for 30A at best .Even if you connected heavier wire the plug itself is still a weak link. I would just go with  high amp binding post and skip the banana feature altogether if your planning on using more than 30 Amps on a regular basis.
« Reply #8 on: May 02, 2019, 07:54:39 am »
Thanks, exatly what I was looking for! :-)
I am thinking of the Keysight 6032A 60V 50A = 1200W Power Supply and an other I have 15V 60A = 1000W Power supply
I will rarely need 60A but I'd rater that the connections can handle max without getting burnt cables, on the other hand, banana plugs are what I use most for the lower ampage and a binding post that can both, would be wary nice. :-)
