OK good. Still curious... I don't think there is any difference in operation between the 6303 and the 6306...
I've got mine fired up right now, noisy fans and all, so if you want me to do any testing let me know please.
Ok so mine is normal to be that loud. I actually got replacement fans with my last Mouser order to fix that!
Anyway, looks like I misread the legend on the config switches, or moving them back and forth cleaned a contact.
1. Set both switches in the middle. In other words, left switch is to the right, right switch is to the left.
2. Verified the current knobs are adequately turned up. When I zero them the channel will switch to CC. When I rotate past 10% or so it's back in CV.
3. Yeah, reads 16V on both. This has been the case. That's how I sleuthed the config switches. The other ways I had them V wasn't tracking. But it was in the original way I tried it?
4. Yeah 16V+
5. and yes 16V-!
Thanks for the help. Have to admit, the size and weight of the 6303D had me a bit intimidated. Worried it would melt if connected wrong.
Now on to actually troubleshooting my EQ and compressor module builds.
