If I recall the name correctly the graph of R vs current should be a 'hyperbola', not a line.
Any small section of it will look a linear relationship, but R approaches infinity when current is 0, and current is 0 when R approaches infinity.
In most practical situations, it is near as dammit linear.
The graph is correct, as it did not specify "for all possible values of I or R".
I'll just have to disagree, with an example.
I would say that 10V and resistances in the 1000 and 3000 ohms range is a practical situation - for example, maybe you are trying to light an LED from a 12V battery.
At 10V, the current through a 1000 ohm resistor is 10mA.
Change that for a 2000 ohm resistor and the current is 5mA.
The linear model gives the following equation:
current = 15mA - R * 0.005
So if the relationship is linear (and we all know that it isn't), current through a 3000 ohm resistor should result in 0mA of current.
And it isn't only extrapolation that fails - a linear model predicts current of 7.5mA with a 1500 ohm resistor - a value that is off by 12.5%.
Can you run that past me again?
Where does the 15mA come from?
Ohm's Law is a simple proportion .
In its most familiar form , we have. I=V/R.
To obviate any problems with battery internal resistance, let's postulate an ideal one volt battery, with an
ideal one Ohm resistor connected across it between its output terminal.
With that resistor kept constant:-
For V=1, I =V/R gives I=1/1 =1amp
Now let us increase V in one volt increments:-
For V=2, I=2/1= 2amp
For V=3, I=3/1=3amp
For V=4, I=4/1=4amp
For V=5, I=5/1=5amp
For V=6, I=6/1=6amp
For V=7, I=7/1=7amp
For V=8, I=8/1=8amp
For V=9, I=9/1=9amp
For V=10,I=10/1=10amp.
Graphing current (I)versus voltage (V) for a fixed R gives a straight line------no logarithms, exponentials, or anything else.
But that's not the graph you were talking about.
Look at the very first post in this thread. It is a graph with current on the horizontal, and resistance on vertical axis, and claiming that the line represents a line of constant
voltage. Remember, Voltage is what's being held constant.
V = I * R
The graph text says that V is a constant. Just arbitrarily, pick V to be 12V.
When R is 12 ohms, I is 1 amp.
When R is 6 ohms, I is 2 amps
When R is 3 ohms, I is 4 amps
When R is 4 ohms, I is 3 amps
When R is 2 ohms, I is 6 amps
When R is 1 ohm, I is 12 amps.
Draw those points on a graph. There is no way you get anything like a straight line.
The last two graphs, showing V vs R for constant I, and V vs I for constant R, are correct, as those are linear relationships.
V = I * R
There is a direct, linear relationship between V and I, (with constant of proportionality R) and a direct, linear relationship between V and R (with constant of proportionality I). But the relationship between I and R is an inverse relationship, which will not produce a straight line graph.
