It's a helluva big project :-) That currently are put a bit on hold when it comes to any practical tests since I'm in the middle of a move from Malaysia back to Dubai...
Well, the compete plans are not drawn out yet, I'm building/planning the major blocks first and then time will tell how to glue them together. It's a bottom up version. I could of course have done it the other way, started with all my blocks in standard TTL ICs and then made the glue in discrete, followed by replacing the chips with insane amounts of PCBs of discretes...
I currently hope to make it a single cycle processor (https://en.wikibooks.org/wiki/Microprocessor_Design/Single_Cycle_Processors) where all info required by one instruction is already there in the 11 bits of code. Then microcode is basically not really necessary and can be replaced by a simple lookup table to enable the correct muxes and other bits and bobs in the modules. At least this is what I hope :-)
The machine will use quite a lot of power when fully operational. For instance the 16 bit program counter module (with an integrated single level stack) is pulling about 4 amps at 2.5 volts.... The Code ram modules (16 words each with two pcs of 4-to-16 decoders) are about 3 amps. And I plan to have 128 of them
We are completely back on topic then!
Because 128 (Code RAM modules) X 3 Amps = 387 Amps + other stuff.
So you will either need a MEGA super duper, fast FET driver, to drive the power FET(S), to make the MASSIVE SMPS.
Or alternatively you will have to bid, on an old pre-historic super Mainframe computer.
I.e. You may have to get hold of an old Cray1 SuperComputer to *Power* your "new", DTL computer.
I.e. You raid/steal the massive power supplies from an old supercomputer, just to get/make a PSU big enough.
(On a more serious note, You can buy large industrial metal framed (or similar), single low voltage SMPS, quite easily, but you may need quite a few of them, by the sound of it).
When/if you finish it, you could send it to Dave, for a (non-destructive) tear-down and interview session. I originally typed this as a joke. But on reflection, it is not such a crazy idea. But I think the computer will weigh and be physically, a tiny little bit too much, to travel as hand luggage (joke).
4 Amps for *JUST* the 16 bit PC counter, sounds rather HUGE. But I later realized, you have gone for VERY low value resistors, for MAX speed, but terrible power consumption.
The room is also going to get very hot. Your design reminds me a bit of the bottom end (simple) PIC micros. They are sort of Harvard with this sort of combined word thing ("all in one", word).
