Electronics => Beginners => Topic started by: advark on September 10, 2020, 09:30:06 pm
Hi everyone,
I'm having some problem solve this circuit and I'm wondering what am I missing. Assuming Vbe is 0.7V and Hfe is 100. I want to calculate Ib and Ic.
First off, I get VR3
VR3 = Vcc *( R3 / ( R3 +R2 ))
= 12 *( 1K / ( 1K +10K ))
= 1.09V
VR2 = Vcc - VR3
= 12 - 1.091
= 10.91 V
Since Vbe is 0.7V and VR3 is 1.091V then VR4 must/should be 0.391V, because VR4 +Vbe should equals VR3.
So Ib (which is the same as IR4) must be 0.391 mA (VR4/R4).
The same goes for IR3 = VR3/R3 = 1.01 mA
Then again, IR2 = VR2/R2 = 1.091 mA
According to Mr. Kirchkoff, IR2 = IR3+ IR4 but 1.091 = 1.01 +0.391 is false... :wtf:
What am I missing here??? My guest is that because R3 is in parallel with R4 my initial formula is wrong. But how can I account for the Vbe drop in that formula (or is there another formula)? :-//
Thanks for any hints.
That's just an approximation. It doesn't account for the current through the base resistor.
Here's a simulation of the transistor biasing with the assumption that Vbe = 0.75V -- you can redo the calculation for a more conventional value of 0.6 or 0.7:
[attach= 1]
Just create variables for the voltage and current for each node, write out the relationships between them and then solve the system of equations.
Yeah some textbooks just assert that the voltage at the base node will be the same as a voltage divider rule, but that is only approximately close when the current through the resistors is orders of magnitude greater than the base current, therefore introducing only a small error.
