Hi Guys,
Im trying to make a digital potentiometer (500k ohm) that is attached to a dc-dc buck converter (ltc3780 to be exact)
I plan on making a very cheap programmable power supply.
Where do I start? What materials do I need?
I already have an arduino, breadboard, 16x2 lcd.
Thanks
Hi
Consider carefully the fact that stability on a buck converter is dependent on the output voltage, output current, the inductor, and the input / output caps. As you change the voltage over a significant range, you will need to change the inductor, the caps, or something else in the circuit. Things may work fine at low current and go nuts at full load.
Most commercial supplies get around this by using the switcher as a pre-regulator. It has a couple of fixed operating points. The rest of the regulation is done with a linear output stage.
I caution because sometimes the failure involves smoke and high output voltage that takes your load with it. I have seen designs that ran for quite a while and then freaked out.
Bob
